Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Reload Thread: Ported box recommendation for 15" hdc3
  1. #16
    AndrewHD's Avatar
    AndrewHD is offline Senior VIP Member
    Oct 2012
    Orange County, CA
    308
    89 Post(s)
    Re: Ported box recommendation for 15" hdc3
    The only reason I'm not recommending the AQ 3500 is that it will need several electrical upgrades like a high output alternator, bigger wire, fuses and more batteries. It can get very expensive. It is your decision though you could always wire it to 4ohms until you get more subs and batteries
    2005 Impala
    DC Power 300 amp alt
    XS Power D3400 under hood
    Big 3 Rockford 1/0 gauge
    Eclipse AVN 726E
    Rockford T3 6.5 component set
    Rockford 1000.4-ADCP
    Rockford 2500.1-BDCP
    FI Q 15 Sealed 2.5 cu. ft
  2. Thanks Kschmitz91 thanked for this post
  3. #17
    Kschmitz91's Avatar
    Kschmitz91 is offline Junior Member
    Jul 2013
    Cleveland
    19
    Yeah that makes sense. I'm sure I will upgrade all of that eventually anyways. Could that sub really handle the 3500w? It looks to be very durable and well built. And thanks so much for all of your help so far I really appreciate it!
  4. #18
    AndrewHD's Avatar
    Oct 2012
    Orange County, CA
    308
    89 Post(s)
    Well if you wire your sub at 4ohms that amp would only produce around 1500 watts RMS. It would be around 4,000 watts at 1 ohm though. And no problem you are lucky to have an SUV I say go big if you can afford it or just save up little by little if you enjoy this hobby. Gotta go for tonight take care and good luck on your setup
    2005 Impala
    Eclipse AVN 726E
  5. #19
    Ahmed Johnson's Avatar
    Ahmed Johnson is offline Senior VIP Member
    Jul 2013
    E-town in the burbs now.
    373
    143 Post(s)
    What style of ported box would you recommend for 4 12"s in an suv? Meaning, where would you place ports and subs? I have 2 only I might get rid of, but then I might just add 2 more
    Quote Originally Posted by AndrewHD View Post
  6. #20
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Be sure to tell any "builder" how much port area you want. While this may not apply to some, it will apply to many local "builders" out there as they may have decent carpenter skills but lack in the design area. So going in with all the info you need upfront is always a good thing.
  7. #21
    Kschmitz91's Avatar
    Jul 2013
    Cleveland
    19
    When I had 4 12's in my car it was a sealed box and it worked well. I just talked to the guy who I bought the hdc3 from and he told me to look into the Atrend 15Lsv box. It's 4.25cu ft tuned at 37. It's definitely cheaper than the quote I received from the guy to make one for me, has anyone ever had a Atrend box?
  8. #22
    Jul 2013
    373
    143 Post(s)
    Atrend's are ok. They are probably the best pre fab I have ever had. The wood is thin and the box is light but as far as a pre fab goes they're ok. A little extra bracing and cover the outside walls with extra wood and you could have an excellent box.
  9. #23
    Kschmitz91's Avatar
    Jul 2013
    Cleveland
    19
    It's made of 3/4" mdf and the front is 1" thick. I found the Atrend 15lsv online shipped for 80. Ill probably just have one made but I thought I would ask since it's relatively cheap and it was recommended to me.
  10. #24
    AndrewHD's Avatar
    Oct 2012
    Orange County, CA
    308
    89 Post(s)
    Quote Originally Posted by Ahmed Johnson View Post
    Subs firing up and slot port firing to the rear (horizontal near bottom). Or you could even do an octoport firing to the rear in the middle of the box with subs firing up also
    2005 Impala
    Eclipse AVN 726E
  11. #25
    Jul 2013
    373
    143 Post(s)
    Ok, so when you say rear, you mean pointing at the trunk? I have seen alot of people with their subs facing up.
  12. #26
    AndrewHD's Avatar
    Oct 2012
    Orange County, CA
    308
    89 Post(s)
    Yea subs up and port firing toward the trunk latch (not sure which SUV you have). But when you open the trunk you will see the port in clear view
    2005 Impala
    Eclipse AVN 726E
  13. Thanks Ahmed Johnson thanked for this post
  14. #27
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    OP you really need to figure out how much power you plan to run. Off a 1200watt amp I'd go 4.5cubes net and wouldn't tune lower then 35Hz. Off a 2kw amp I'd do 4.25 net with the same tuning. 16^2 port per cube.
    I've built a ton of daily boxes like that for AQ's and they work out very well.
  15. #28
    Kschmitz91's Avatar
    Jul 2013
    Cleveland
    19
    I still haven't gotten around to actually making the box yet, but I have been looking into using an aero port for it. From what I have read it's easier to make and I like the fact that I can change the tuning of the box easier. I'm definitely going to be using a 2000w amp with it. Does anybody know if the hdc3 would work well with aeroport(s)?
  16. #29
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Aero makes no diff, any sub will work with them "assuming" port area/tuning is correct
  17. #30
    Kschmitz91's Avatar
    Jul 2013
    Cleveland
    19
    That's what I thought, thank you.
  1. what sub is this - box recommendation for 15"
    By plugger in forum Enclosure Design & Construction Help
    Last Post: 03-02-2013, 11:37 AM
  2. Box recommendation for 15" RF HX2
    By golffanatic in forum Subwoofers
    Last Post: 02-24-2010, 12:49 AM
  3. box recommendation for 15" RD Alpha v2
    By truckcap22 in forum Enclosure Design & Construction Help
    Last Post: 09-03-2009, 11:44 PM
  4. Box Recommendations for 15" Kicker CVX
    By 302yota in forum Enclosure Design & Construction Help
    Last Post: 09-08-2008, 09:13 PM
  5. I need an aero port box designed for 15" RD Alpha
    By 528hz in forum Enclosure Design & Construction Help
    Last Post: 06-20-2008, 05:28 PM
Tags for this Thread
