Results 1 to 5 of 5
Reload Thread: Newbie needs help. (Subs, Amps, Box)
    WhatsAminiTruck's Avatar
    WhatsAminiTruck is offline Senior VIP Member
    Jul 2013
    STL Missouruh
    188
    71 Post(s)
    Alright, so my final plan is to have two 500 watt 10" subs in two separate boxes (one sub in each box) , on a 1000 watt amp or two 500 watt amps... but I only have the money to do half of it right now... so one 10" sub for now.
    (Scroll to * for short story shorter)
    I don't know much about car audio, but I know the basics of the basics... and when I went to my local car audio shop(s), they were trying to tell me to shove two 12" subs under my back seat, and put an 8 on each side... in between the seat and the cab wall. -__-
    I know at least that a sub needs a certain amount of air to move around to run effectively, and my extended cab dodge Dakota doesn't have very much. I initially wanted to put in two 12s, but two 10s will be just effective, if I build the right box. And that's what I'm here for.
    A friend of mine was going to show me the ropes, and help me design a box, because he knew a guy where you just tell him your make and model of vehicle, and he gives you the optimal box blueprints for your vehicle... but that friend of mine just passed away (Jerry Yaeger if you knew him... he was pretty big in the Mid America Audio Drag Scene). So, in order to not get completely fucked at a car audio shop, I came here
    I want to know how big my box should be, and how it should be designed to "Get the most" out of a (and eventually two) 10" sub woofer(s) for my 96 Dodge Dakota.
    Vehicle : 1996 Dodge Dakota SLT (extended cab)
    Location in the vehicle: Back Seat "Bench" with seat removed
    Space available (Length x Width x Height): 21 x 11 x 24 (in.)
    Subwoofer make and model: I want a 10" 500 watt sub, any suggestions? (Medium quality)
    I like American Bass subs... I would prefer if one of theirs would work. (Not DXs)
    Subwoofer Size: 10"
    Number of Subwoofers: 1 (for now)
    type of Port (Kerfed, Slot, Aero, etc.): Uhhh, best/cheapest? lol
    What type of music do you like?: It will be playing a bit of everything. Electronic, country, rap, and hip hop.
    Is your goal SPL or Everyday Music?: Everyday Music
    Tuning Freq (Hz): Most effective?
    Volume : Loud?
    Questions: What would be better for two 500 watt 10s? one 1000 watt amp, or two 500 watt amps?
    Current: 240amp Mechman Alt, Yellowtop in the back, Two SA-6.5s and two tweets in each door powered by an LA-4200, Two Sundown SA-12s in a prefab powered by an SAZ-1500.
    http://www.stevemeadedesigns.com/board/topic/178898-vehicle-dodge-dakota-1996/
    ^my ride
    Jul 2013
    STL Missouruh
    188
    71 Post(s)
    Re: Newbie needs help. (Subs, Amps, Box)
    Rage Bump.
    ^my ride
    Jul 2013
    STL Missouruh
    188
    71 Post(s)
    Double Post, WHOOPS
    ^my ride
    des343's Avatar
    des343 is offline CarAudio.com Elite
    Feb 2011
    Kalamazoo, MI
    994
    436 Post(s)
    Try american bass XOs any why not DX? Also what is your actual budget
    Jul 2013
    STL Missouruh
    188
    71 Post(s)
    I freaking HATE the huge DX symbol on the DX cones. That, is the absolute only reason.
    And I mean, for right now... I'm looking at under $500
    ^my ride
  1. Need a sub, amp, box for $175!
    By ravicus in forum Subwoofers
    Last Post: 11-19-2011, 02:37 PM
  2. Old car needs help (Sirius/Amp/Box)
    By Marine1371 in forum Wiring, Electrical and Installation Help
    Last Post: 04-11-2008, 12:43 PM
  3. Newbie. need help wiring amp
    By molotov in forum Wiring, Electrical and Installation Help
    Last Post: 09-18-2005, 10:43 AM
  4. Newbie. need help wiring amp
    By molotov in forum Amplifiers
    Last Post: 09-17-2005, 08:31 PM
  5. Newbie needing help with amp wiring placement
    By HPB in forum Wiring, Electrical and Installation Help
    Last Post: 07-30-2004, 10:20 AM
