Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 1 to 15 of 167
Reload Thread: The 4th order thread
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    There seems to be a lot of misinformation regarding 4th orders these days... So maybe this thread will help to get rid of some of that. Simply ask a question, and I, or anyone else who has knowledge of 4th orders for that matter will answer it. Please keep it strictly about 4th orders. Ask away!
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: The 4th order thread
    heres the beginning of my current 4th order. I will be making a 12" aero, that is what the ring is for. here is the Fc of my rear chamber. Measured with the vehicle sealed and the loading wall off. Its just about right where I want it to be.
    5.3bowtie's Avatar
    5.3bowtie is offline CarAudio.com Elite
    Mar 2008
    Detroit, MI
    950
    4 Post(s)
    42 Post(s)
    I will be the first to ask.......Always heard 4th orders, or bandpass boxes in general, had a certain frequency range in the "middle" that would be "dead" with the subs playing fequencies on each side of the "dead zone". Is this true?
    Nice looking box btw.
    2002 Chevy reg. cab
    Alpine 9833 / HAT L1v2 / Silver Flutes / IDQ 10
    Sony XM-260G / 2x Sony XM-2100G
    2009 Pontiac Vibe
    Currently Stock
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by 5.3bowtie View Post
    entirely false, actually, its sort of the opposite of that. they will play a bandwidth, but will roll off above and below that bandwidth, however it is a gradual roll off because of the sealed side of the enlcosure.
    5.3bowtie's Avatar
    Mar 2008
    Detroit, MI
    950
    4 Post(s)
    42 Post(s)
    Ah ok, so how large of a bandwidth can it hold? Is this dependant uppon drivers, box, both? How does the size of the ported section relative to the size of the sealed section determin box characteristics?
    Sorry for all the newb questions, never had or built or played with a 4th order before......
    2002 Chevy reg. cab
    2009 Pontiac Vibe
    Currently Stock
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    One thing I see a lot of in people's build thread is using a really stiff, high Fs woofer (i.e. like DD's) in a 4th and using a small sealed portion, creating a very high Fc/Qtc and they get no lows out of it.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    Garcia915's Avatar
    Garcia915 is offline Senior VIP Member
    Jan 2013
    Odessa, Tx
    174
    59 Post(s)
    Can u guys list a few subs that are 4th order friendly? Do type r's do we'll in 4th orders?
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    You want to look for a high Qts and a low Fs, and a higher Vas generally.
    Type r's are 4th order friendly.
  9. #9
    vetkilr's Avatar
    vetkilr is offline CarAudio.com Veteran
    Mar 2006
    brandon,fl
    3,334
    53 Post(s)
    DC level 3's and 4's work great. PSI level 1's and 2's work as well. Depending on power you can get them minus a spider to make them more efficient. Seen two 12" psi level one's with only 1 spider sound really loud on a BC2000d.
  10. #10
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    very dependent on the rear chamber, woofers, and ratio. Typically, a larger ratio of sealed to ported will have a smaller passband, but a higher spl. But, if you want to get your low end back, you can throw more power at your woofers. That has worked for me quite well, if your woofers can handle it.
    questions are a great thing! thats why I made this thread!
    Quote Originally Posted by Buck View Post
    Most of the people that I have met/seen that do that, are using very large ratios (above 5:1) and are strictly doing it for spl burps.
    Quote Originally Posted by Garcia915 View Post
    type rs would be great, soft suspension and low fs, otherwise, The sa series is another favorite.
    yup yup. I would like to swap out the sa's for r's just for an experiment, but the r's wouldnt fit in my flush mount lol
  11. #11
    5.3bowtie's Avatar
    Mar 2008
    Detroit, MI
    950
    4 Post(s)
    42 Post(s)
    When you say a 5:1 ratio, does that mean the sealed portion or the vented portion is larger?
    2002 Chevy reg. cab
    2009 Pontiac Vibe
    Currently Stock
  12. #12
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    the vented side, which is referred to as the front chamber, is the larger portion. and it is always either the same size, or larger than the sealed portion, which is referred to as the rear chamber. so 5:1 = Front:rear
  13. #13
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    You could start by explaining the fact that the term "4th order" is a bit of a misnomer since a regular ol' ported box is also a 4th order. Lol.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  14. #14
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by TaylorFade View Post
    I thought about just filling up the first post with everything that I know, but thats no fun, and too much information at once is hard for some people to comprehend. so please, take it away if you wish.
    ---------- Post added at 12:09 PM ---------- Previous post was at 12:09 PM ----------
    I suppose we could start using the term "4th order BP"
  15. #15
    TaylorFade's Avatar
    Dec 2009
    Baton Rouge, La.
    3,019
    19 Post(s)
    1292 Post(s)
    Quote Originally Posted by DbDesigns View Post
    Or single reflex bandpass. But that could include a series tuned "6th" order and quasi 8th too, I suppose.
    Anyway... why don't you go into detail about how you arrived at the graph and the tuning for the box you posted for those who don't know. And why we tune to sealed resonance.
    And how one might arrive at tuning without a "Woofer Tester."
    How ratios affect bandwidth.
    How to figure port area. And how tuning or other factors affect said area.
    How the size of the sealed chamber affects response.
    TaylorFail
    Taylorfail, v.2
    tailorFail v.3
    TaylorFail v.4
    TaylorWin v.1?
  1. Starting the 4th order
    By Durango03 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 02-13-2013, 01:40 AM
  2. To the 4th order wizards out there
    By sxpimpin in forum Enclosure Design & Construction Help
    Last Post: 06-01-2011, 09:37 PM
  3. 4th order build for the 06' XXX 15
    By mobeious in forum Enclosure Design & Construction Help
    Last Post: 02-08-2007, 08:20 AM
  4. Got the Mach 5 in a 4th order...
    By jmanpc in forum Subwoofers
    Last Post: 12-24-2006, 07:22 PM
  5. Bad news on the 06' XXX 15 4th order build
    Last Post: 11-14-2006, 06:59 PM
