Page 9 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 121 to 135 of 167
Reload Thread: The 4th order thread
  1. #121
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: The 4th order thread
    gah, toasted my 3500. blew a few output fets. oh well, at least I can fix it myself. just got to wait on my fets and drivers to get here, and I might mod it to do [email protected] but well see if I feel like pulling the board or not
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
  2. #122
    jdawg90's Avatar
    jdawg90 is offline CarAudio.com Veteran
    Dec 2007
    alberta
    2,762
    19
    536 Post(s)
    I take it Vb is box volume? Is that sealed or ported? I plugged that number in the formula you gave for Fc with the specs and reccomended ported box specs for the sa-12 v1 and v2 and got around 100 both times. For the sealed box volume I got closer to 200.
    The formula is Fc=sqrt[(Vas/Vb)+1]*Fs correct?
  3. #123
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by jdawg90 View Post
    100 or 200 what? sa12 for example. vas=21.21, fs is 33.7. now, take 21.21/28.3168(1 cu ft in ltrs) this will give you .75 if you round it. now, add 1, and you get 1.75. then sqrt that and you get 1.33, then multiply that by the fs, so 33.7*1.33 and you get 44.821. that is your Fc.
    1999 Tahoe
    2 sa12s
    4th order
  4. Thanks jdawg90 thanked for this post
  5. #124
    shauncox26's Avatar
    shauncox26 is offline CarAudio.com Elite
    May 2013
    oxford ms
    1,694
    10 Post(s)
    606 Post(s)
    Hey guys newb on the 4 ths. Going to try on with my obsidian 12 s. So the larger chamber should be the ported one.
  6. #125
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by shauncox26 View Post
    yes.... did you read the first page? I would start there
    1999 Tahoe
    2 sa12s
    4th order
  7. #126
    shauncox26's Avatar
    May 2013
    oxford ms
    1,694
    10 Post(s)
    606 Post(s)
    Yes i did. Ok oas fs is 33 and the vas is 34.4 vb is 1.5 ft2 or 42.4752 lts. I came up with 44.3982 for my fc. So i tune my ported chamber to around 44 hz correct. So much to take in.
  8. #127
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    yup, youre on the right track
    1999 Tahoe
    2 sa12s
    4th order
  9. #128
    shauncox26's Avatar
    May 2013
    oxford ms
    1,694
    10 Post(s)
    606 Post(s)
    So i was thinking 1:3 was a good starting point. Ill post pics once i start.
  10. #129
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    I may try 1:2 first.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  11. #130
    jdawg90's Avatar
    Dec 2007
    alberta
    2,762
    19
    536 Post(s)
    Quote Originally Posted by RangerDangerV2 View Post
    I didn't pay attention to units... I'm getting the right answer now.
    What's the difference in using a passband ripple (S) of .5, .6, and .7 when designing a box?
  12. #131
    Beatin''s Avatar
    Beatin' is offline CarAudio.com Elite
    Nov 2012
    MI
    998
    574 Post(s)
    what!? The ported chamber has to be the bigger one? WinISD shows too much peak and group delay.
    All day I'm clippin'
    voltage be dippin'
    I don't give a damn,
    cause my trunk always hittin'!
    creating a proper sound wave. Step one, turn it up until clipping. Step two, done.
  13. #132
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by Buck View Post
    I would disagree, its easier to shrink down than gain more space.
    Quote Originally Posted by Beatin' View Post
    forget winisd, it is highly innacurate.
    1999 Tahoe
    2 sa12s
    4th order
  14. #133
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    I have been getting quite a few pms lately, and it seems that all of you think that you need winisd to design a 4th order.... well, you dont. take the steps that have been explained, build it, test it, enjoy it.
    1999 Tahoe
    2 sa12s
    4th order
  15. #134
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    people.... if you pm me asking for advice, then listen to what I have to say. dont keep asking me about modeling programs, because they are useless. Ive had to tell about 10 people that in the past 2 days, and nobody is listening. If you pm me, and dont listen to my advice, then I will not respond back.
    1999 Tahoe
    2 sa12s
    4th order
  16. #135
    jdawg90's Avatar
    Dec 2007
    alberta
    2,762
    19
    536 Post(s)
    How does a high ratio effect the frequency spectrum the sub plays at ? Does it simply shrink it with the peak being the higher? In your pm you said if you want to hit the lows go with a larger FC. What exactly do you mean by that? A sub with a higher FC (I'd think it'd be the opposite, that's why I'm kinda confused)?
  1. Starting the 4th order
    By Durango03 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 02-13-2013, 12:40 AM
  2. To the 4th order wizards out there
    By sxpimpin in forum Enclosure Design & Construction Help
    Last Post: 06-01-2011, 08:37 PM
  3. 4th order build for the 06' XXX 15
    By mobeious in forum Enclosure Design & Construction Help
    Last Post: 02-08-2007, 07:20 AM
  4. Got the Mach 5 in a 4th order...
    By jmanpc in forum Subwoofers
    Last Post: 12-24-2006, 06:22 PM
  5. Bad news on the 06' XXX 15 4th order build
    Last Post: 11-14-2006, 05:59 PM
