Page 7 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 91 to 105 of 167
Reload Thread: The 4th order thread
  1. #91
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: The 4th order thread
    Quote Originally Posted by Buck View Post
    I'm sorry
    So those are sa-12's you are running? What's the specs of the box now?
    yes, sa12s, rear chamber is 2 cubes. thats all im giving out lol
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
  2. Dislikes Spl4200 disliked this post
  3. #92
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    heres the innards though lol
    1999 Tahoe
    2 sa12s
    4th order
  4. #93
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,671
    29 Post(s)
    1130 Post(s)
    Yes, that's what I've used on them as well.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  5. #94
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    id go smaller, but the tahoe peaks so low, theres not point to it. and if one were to go smaller, the woofers would be getting beat on fur sure... I doubt the surrounds would hold up lol. but 1-1.2 is optimal.
    1999 Tahoe
    2 sa12s
    4th order
  6. #95
    Buck's Avatar
    May 2008
    Nashville
    18,671
    29 Post(s)
    1130 Post(s)
    There is a certain trust or faith you have to have with people when it comes to mechanical failure. I say that because you have to assume people will test the limits of that box, so it's fair to give a little over-excursion room, as in more cone control. So I think long and hard about the size of my chambers.
    If you know what I mean
  7. #96
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    ******, the way I like it.
    1999 Tahoe
    2 sa12s
    4th order
  8. #97
    Buck's Avatar
    May 2008
    Nashville
    18,671
    29 Post(s)
    1130 Post(s)
    One guy was running almost 8 cubes with 4 12's to achieve the Fc he wanted. I understand that, but for most I wouldn't feel comfortable doing that even if the numbers did match up. If it was my box, wouldn't be a second thought about it because I know how to spot problems. That's why bandpasses are fun. Trying to get the best performance while trying not to mechanically destroy your woofer. Maybe that's the name of the game.
  9. #98
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    one thing I learned, small rear chamber=more port larger rear=less port. Im as small as I want to go rear chamber wise, but I still only have like .25" of excursion, now, since I have a large ratio, the woofers arent pressurizing the enclosure as I wish they were, thats why im chopping the port down. That will give me a higher tuning, and more excursion at my peak.
    1999 Tahoe
    2 sa12s
    4th order
  10. #99
    Buck's Avatar
    May 2008
    Nashville
    18,671
    29 Post(s)
    1130 Post(s)
    Quote Originally Posted by RangerDangerV2 View Post
    smaller chamber = higher Fc. The higher you tune, the higher your vent mach is given same power and port area. So it makes sense why your port velocity would increase when you shrink the rear chamber based on that logic.
  11. #100
    noble brown's Avatar
    noble brown is offline Senior VIP Member
    Apr 2013
    Hermitage, pa
    316
    3 Post(s)
    119 Post(s)
    ok so vas:46/Vb:2.2=20.9 + 1 = 21.9, sqrt = 4.6 x Fs:27 = 126, which should be my Fc of my rear chamber right? it seems really high. am i messing something up?
  12. #101
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by noble brown View Post
    vb needs to be in liters. you have to convert it from cu ft.
    1999 Tahoe
    2 sa12s
    4th order
  13. #102
    Apr 2013
    Hermitage, pa
    316
    3 Post(s)
    119 Post(s)
    specs claim the 46 is in liters. a missprint?
  14. #103
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    vas is in liters. you need your Vb to be in liters as well.
    1999 Tahoe
    2 sa12s
    4th order
  15. #104
    Apr 2013
    Hermitage, pa
    316
    3 Post(s)
    119 Post(s)
    wouldnt that give me an even larger number, 46 cuft is 1302 liters
    ---------- Post added at 11:21 PM ---------- Previous post was at 11:21 PM ----------
    oh ok
    ---------- Post added at 11:22 PM ---------- Previous post was at 11:21 PM ----------
    duh
  16. #105
    Apr 2013
    Hermitage, pa
    316
    3 Post(s)
    119 Post(s)
    ok so Fs of rear is 35hz. i multiply this by my desired ratio... whats my next step
  1. Starting the 4th order
    By Durango03 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 02-13-2013, 12:40 AM
  2. To the 4th order wizards out there
    By sxpimpin in forum Enclosure Design & Construction Help
    Last Post: 06-01-2011, 08:37 PM
  3. 4th order build for the 06' XXX 15
    By mobeious in forum Enclosure Design & Construction Help
    Last Post: 02-08-2007, 07:20 AM
  4. Got the Mach 5 in a 4th order...
    By jmanpc in forum Subwoofers
    Last Post: 12-24-2006, 06:22 PM
  5. Bad news on the 06' XXX 15 4th order build
    Last Post: 11-14-2006, 05:59 PM
