Page 5 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 61 to 75 of 167
Reload Thread: The 4th order thread
  1. #61
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: The 4th order thread
    Quote Originally Posted by Buck View Post
    What frequency? Isn't it low?
    I compliment your db achievement.
    32hz lol pretty low to me
    ---------- Post added at 11:11 PM ---------- Previous post was at 11:10 PM ----------
    and thanks!
  2. #62
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    best so far, not bad for less than 500 watts
  3. Likes n8skow liked this post
  4. #63
    n8skow's Avatar
    n8skow is offline CarAudio.com Elite
    May 2009
    Kansas City, MO
    1,291
    263 Post(s)
    That should be close to a 148 on 1k, turned it up yet?
    Quote Originally Posted by RangerDangerV2 View Post
    National Finals
    Oct. 28-29th, 2017 - Sedalia Missouri
  5. Likes RangerDangerV2 liked this post
  6. #64
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by n8skow View Post
    I could wire to .5... but im enjoying 2 ohms lol. Id try for the b1 record, but the b2 record is quieter lol.
  7. #65
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    tested more today... couldnt get more than the 145.18, morning it averages 144.5ish, midday and night after its been in the sun all day it meters about a 141.5. really amazing how much the temp of the vehicle matters. but ive got some plans, so hopefully Ill see that 150 by sunday.
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
  8. #66
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    some other cool stuff, does a 160.2 in the port, and 134.xx 1 ft outside the window, not too shabby I would say. both those are at 33hz.
    1999 Tahoe
    2 sa12s
    4th order
  9. #67
    noble brown's Avatar
    noble brown is offline Senior VIP Member
    Apr 2013
    Hermitage, pa
    316
    3 Post(s)
    119 Post(s)
    I wish I could understand half of what you cats are saying, but I'm learning. I am thinking of building a fourth for a pair of type r's. So I throw some numbers in a program I found on the net and I have some questions. First shouldn't the volume need to be larger then with a ported? The program o only allowed for calculations for one speaker at a time so do I just double the volumes for two? Is a db gain of two or three audibly noticeable, if so how much. For an everyday driver I wanna be able to get the lows nicely (listen to rap) but I also wanna gain as much as I can too. Currently I'm tuned to 32hz and I like it but wondering if it's practical to sacrifice a bit of the low end for some gain. I guess I'm curious how low rap on average gets
    . Isn't low 30's rare? also is the functional output of a given port the same regardless of shape as long as the volume is the same?
  10. #68
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by noble brown View Post
    forget the program. do the equation to find the Fc of your rear chamber, then multiply that by the ratio that you wish to achieve. a 3db gain is very noticeable. depending on the design of the 4th order, you can dig very low, and be very loud on little power, like my enclosure. and some port shapes are louder than others, but that depends on the application. I would go with a slot port, very easy to do
    1999 Tahoe
    2 sa12s
    4th order
  11. #69
    Apr 2013
    Hermitage, pa
    316
    3 Post(s)
    119 Post(s)
    What ratio would you recommend for my application. I will do the math and figure it out. Will I have to go large then my 4.2cu ported I have now to get the gain I'm looking for or will that depend on what I come up with on my math
  12. #70
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    id go with the standard 2:1, and yes it will probably be a tad larger than your enclosure now, gain is really dependent upon design, but some people see a 6+ db gain. but put it this way, I used to run 4 12s in a ported enclosure, and I was doing 145.1 on about 2k, now, im running 2 sa12s, and doing a 145.1 on about 400 watts. lol
    1999 Tahoe
    2 sa12s
    4th order
  13. #71
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    This post has me wanting to do a 4th order trunk build... even though my rear deck opening makes my trunk into a 6th order of sorts already lol
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  14. #72
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by Tenacious. View Post
    do it man! my numbers dont lie lol! 4th orders can do some magical things
    1999 Tahoe
    2 sa12s
    4th order
  15. #73
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    I may throw some ideas around, I've got about 8 cubes to work with (before any displacements) and this would be about the only way to do a cabin firing build in my car due to the rear deck being so short. Now that I think of it, I may be able to squeeze a little more volume with the front chamber sliding under the rear deck.
    Can you think of any higher powered woofers that work well in a 4th order? More likely than not it'll be 2 12s or 1 15 on around 4k - although I'm really not sure how rise effects a 4th order bandpass compared to a regular ported enclosure
  16. #74
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    rise is really dependent on ratio... large ratio like mine, equals lots of rise. but rise is actually efficiency. I rise from 2.3 ohms to 8.8 at 33hz. now, if you were to do a 1:1 or a 2:1 you would have less rise. but honestly, id go zv3s, or even sas if you have a 4k amp, because you will never see 4k out of it.
    1999 Tahoe
    2 sa12s
    4th order
  17. #75
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Yeah, when competing a huge ratio would be better because of rise for me (MECA is classified by cone area + fuse rating, could run a tiny fuse with that kind of rise) but I'm not too concerned with competing right now. I'm just tired of being limited to a trunk build and want to switch it up and possibly get louder. Most of my listening is music at full tilt for long periods of time while driving lol
    2 Zv3 10s with a huge ratio on a ton of power would absolutely rape everyone else in the trunk class
  1. Starting the 4th order
    By Durango03 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 02-13-2013, 12:40 AM
  2. To the 4th order wizards out there
    By sxpimpin in forum Enclosure Design & Construction Help
    Last Post: 06-01-2011, 08:37 PM
  3. 4th order build for the 06' XXX 15
    By mobeious in forum Enclosure Design & Construction Help
    Last Post: 02-08-2007, 07:20 AM
  4. Got the Mach 5 in a 4th order...
    By jmanpc in forum Subwoofers
    Last Post: 12-24-2006, 06:22 PM
  5. Bad news on the 06' XXX 15 4th order build
    Last Post: 11-14-2006, 05:59 PM
