Page 2 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 16 to 30 of 167
Reload Thread: The 4th order thread
  1. #16
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: The 4th order thread
    Quote Originally Posted by TaylorFade View Post
    Or single reflex bandpass. But that could include a series tuned "6th" order and quasi 8th too, I suppose.
    Anyway... why don't you go into detail about how you arrived at the graph and the tuning for the box you posted for those who don't know. And why we tune to sealed resonance.
    I purchased a DATS (first I did some math but I will delve into that later) placed my enclosure in the tahoe, vehicle sealed, loading wall off of the enclosure. Then I ran an impedence sweep, which showed me at what frequency my imp. peaked at. That is called the Fc or sealed resonance.
    And how one might arrive at tuning without a "Woofer Tester."
    the equation is (Vas/Vb)+1, then sqrt that number, and multiply by the fs of the woofer. when I did this I got an Fc of 45.5 hz, real world with the dats was 45.09. quite close if you ask me, so I would have no problem trusting the equation.
    How ratios affect bandwidth.
    to put it in simple terms, large ratio= smaller passband smaller ratio=larger passband. but I have found that is not always the case. many more factors that have control over your bandwidth than just the ratio
    How to figure port area. And how tuning or other factors affect said area.
    im a test and find out type of guy, but I usually start off with 1/2 port area to cone are (my enclosure uses a single 12" aero, because I have 2 12s) I prefer to go bigger, because shrinking down is easy. But some people have luck with 1/3 port to cone area. I have had good luck with 1/2 though. But many things come into play here such as goals, woofers, vehicle, etc. just like any other enclosure.
    How the size of the sealed chamber affects response.
    more simple terms, typically, large rear= lots of low end, but lacks on the higher end from what I have seen, and the opposite applies for smaller rear ends. But I am a fan of my Fc being in the 45-48hz range for daily.
    I am not the best at explaining things, because I cant really put them into simple terms very well. hopefully everyone understands this. Also, I am no 4th order master, I dont have all of the answers, but I do know a good amount, mostly from testing, and educating myself. So please, if anyone else has some things that they would like to add, feel free to do so, I could always use some more information!
  2. Thanks TaylorFade thanked for this post
    Likes SounDrive, Silverado SS, Buck liked this post
  3. #17
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Quote Originally Posted by DbDesigns View Post
    I'm right there with you.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  4. Likes RangerDangerV2 liked this post
  5. #18
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by Buck View Post
    like I said too... lots is woofer dependent as well. Thats why the sa series is my favorite. they are kind of a middle category woofer. they can work well in almost anything, and they really shine in the 4th orders. plus they dont need a large rear chamber at all.
    ---------- Post added at 02:35 PM ---------- Previous post was at 02:34 PM ----------
    but yeah, thats why I said "typically" lol power is a factor as well
  6. #19
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Power is a big factor especially when trying to mix lows with high power, trying to balance the lower Fc with mechanical handling. Low Fs woofers really make that easy, like the RE XXX.
  7. #20
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    fur sure lol
  8. #21
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    I've always thought home theater 4th order were interesting. It's where you do something like 3:1 ratio, except your larger section is the sealed one and the smaller one is the ported. Gotta get those 10 hz lows.
  9. #22
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    This thread makes me want to grab a pair of AA Havocs
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  10. #23
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by Tenacious. View Post
    get some sa's yo. cheap, and they can get stupid. at least mine do... lol
  11. #24
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    The end plan in my explorer is 8 sa-15's in a 4th order wall
  12. #25
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    id just get that fan that can play down to 1hz... you may not be able to hear it, but you can def feel 1hz @120 db lol
  13. #26
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    one of my buddies is doing 12 12s in a 4th, and another guy I know just did 8 15s in a 4th on 4 ns1s.
  14. #27
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Fi IB3 is where it's at. I say some video where this dude was shaking his old house with 4 18's mounted in a wall, like literally in one of his walls on his house. His ceiling fan was shaking up and down like in an earthquake playin like 5 hz or something stupid.
  15. Likes Bassman999 liked this post
  16. #28
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Before or after you completely destroy the thing from flex? lol
  17. #29
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    I'll build the wall when the hatch is unrepairable.
  18. #30
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    If you wake up with a destroyed hatch one day.... it wasn't me
  1. Starting the 4th order
    By Durango03 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 02-13-2013, 01:40 AM
  2. To the 4th order wizards out there
    By sxpimpin in forum Enclosure Design & Construction Help
    Last Post: 06-01-2011, 09:37 PM
  3. 4th order build for the 06' XXX 15
    By mobeious in forum Enclosure Design & Construction Help
    Last Post: 02-08-2007, 08:20 AM
  4. Got the Mach 5 in a 4th order...
    By jmanpc in forum Subwoofers
    Last Post: 12-24-2006, 07:22 PM
  5. Bad news on the 06' XXX 15 4th order build
    Last Post: 11-14-2006, 06:59 PM
