Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: Looking for Box Design Help!
  1. #16
    T.I.K.'s Avatar
    T.I.K. is offline F*ck it, we'll do it live
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Re: Looking for Box Design Help!
    Quote Originally Posted by Oraclem19 View Post
    This is where I was confused.
    This is also why I am considering keeping two demo boxes around. One for DD, tuned up into 40-42hz, and one for lows and demoing rap, tuned at like 35 33s.
    Then again with how my system was hitting last time I played with this 35 box if I break 1000w kind of feels like a 35 tuned box can take care of anything up until 60s 70s adequately.
    You could technically tune in the upper 30's/low 40's and still play all through the 30's with authority. It's all in the box modeling though. As soon as you start playing below tuning, you lose more and more of the acoustic suspension provided by the box, so cone control is purely on the suspension and motor.
    I personally don't know how to model that, I'm sure if you consult one of the professional designers on here they could help you, or at least point you in the right direction.
    My point being that you could possible build a box that satisfies both styles of music. It would certainly be more convenient than building two boxes.
    Get taken down to funky town
  2. #17
    Oraclem19's Avatar
    Oraclem19 is offline Senior VIP Member
    Mar 2013
    United States
    177
    74 Post(s)
    Quote Originally Posted by T.I.K. View Post
    I'll put this out there right now then, anyone willing to help(your time will be made worth it) me achieve knowing how to get to these kind of designs, and confirm they will work before putting them in wood, send a message. Have and can use all current programs inc. Hornresp.
    Have been trying to play some 32 hz songs on this box and while the tone plays, I can't tell if the box is unloading and damaging the woofer.
  3. #18
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    If the sub is being driven past the mechanical limits, you'd more than likely be able to hear abnormally loud mechanical noise or the sub bottoming out. Also, when the coil leaves the gap, distortion should be noticeable.
    If you get yourself a DD-1, it will listen for any distortion, not just distortion from clipping(although that is what it is primarily used for). It would be easy enough to set gains with that and keep your coil inside the gap.
  4. #19
    Oraclem19's Avatar
    Mar 2013
    United States
    177
    74 Post(s)
    It sounds a bit odd at 32, must not be much distortion if I'm having problems telling if I'm distorting.
    Link to DD-1 doing this? Didn't know the thing had a mic on it.
  5. #20
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    Wow, I must be high. No the DD-1 doesn't work that way.
  6. #21
    T.I.K.'s Avatar
    Oct 2010
    Michigan
    25
    4,163
    848 Post(s)
    point stands, once the coil leave the gap, it should audibly distort pretty heavily.
  7. #22
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,102
    15
    38 Post(s)
    4138 Post(s)
    Quote Originally Posted by dbeez View Post
    Evidently tyga rack city and put on and such songs only dig low when slowed down.
    Whatever. Meanwhile the other 14-18 tracks on any of the CD's those "songs" come from are in the more traditional music range. The larger problem is that most of the subs that we're dealing with here simply want to play peaky and you're going to sacrifice bandwidth somewhere for the sort of output we like. I used to always tune in the high 20's so that I could play down to 18hz and after going out on a limb and doing some low 40's tuning I'll never go back except for movie sound effects I'm not missing anything
    More people would make a huge port for high tuning and an insert to tune lower when desired, or use external aero-octo type port and you could choose a port based on what you wanted to do and 8 bolts would swap them out.
    In similar news, I actually have a box I'm trying to tune now 8 cube 16X 8.5" port 17" long that's peaking at 35hz. I'm not impressed and trying to tune higher. Really I have no idea why it's behaving like It is, going to trim a few inches off it and try to get it up @ 40-42
  8. #23
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    Quote Originally Posted by hispls View Post
    Theres many songs that drop low thats not slowed is my point you like mid to higher bass better thats good I have built many low tuned boxes that will play from the 20's to the 60's all day.
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
  1. looking for box design help or ideams massive audio dmx 12
    By sportsspecial in forum Enclosure Design & Construction Help
    Last Post: 04-22-2011, 08:05 PM
  2. Need help for Box Design on a 15 inch Kicker L7
    By BadAndy44 in forum Enclosure Design & Construction Help
    Last Post: 04-03-2007, 09:18 PM
  3. Desperate for box design help!!
    By phantom240 in forum Enclosure Design & Construction Help
    Last Post: 09-10-2006, 10:45 AM
  4. airspace help needed for box designers???
    By DoubleE in forum Enclosure Design & Construction Help
    Last Post: 05-11-2006, 07:00 PM
  5. box design help for orion h2 12.2
    By 3BiP in forum Enclosure Design & Construction Help
    Last Post: 03-15-2004, 02:58 AM
