Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 49 of 49
Reload Thread: RE XXX 15: sound quality build; ported or sealed
  1. #46
    mugen08's Avatar
    mugen08 is offline Win aplenty
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Re: RE XXX 15: sound quality build; ported or sealed
    My front stage (2001 BMW 325ci) consists of 2-3.5" drivers and 2-5 1/4" drivers, I'm assuming the 5 1/4" are mid bass only...? Anyway, I am trying to come up with a front stage that will compliment the XXX; obviously something with good low end extension down to what, 60 hz or so which is what I may be setting my crossover at...?
    I did the math and I should be able to squeeze a 5 cube box in my trunk plus extra battery and amp..
    Hmm, I wonder if I could do an IB setup..
  2. #47
    Dec 2007
    Canada
    74
    7 Post(s)
    Quote Originally Posted by mugen08 View Post
    My front stage (2001 BMW 325ci) consists of 2-3.5" drivers and two 5 1/4" drivers, I'm assuming the 5 1/4" are mid bass only...? Anyway, I am trying to come up with a front stage that will compliment the XXX; obviously something with good low end extension down to what, 60 hz or so which is what I may be setting my crossover at...?
    Either way, I'm curious to know how it turns out for you.
    I may try an IB setup with mine. I'm thinking I could build an mdf cargo shelf type thing in the back of my Jeep Liberty. It would be flush with the top of the seat backs. Sub would be firing up. That could be something I could do with the next to no power tools that I have.
  3. #48
    mugen08's Avatar
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Quote Originally Posted by eradicator006 View Post
    Or build a 25 cube ported box for it!
    Data-Bass
    At 34.5 cubic feet of external volume and an estimated 320lbs this custom system is by far the largest that has been tested thus far. The huge enclosure enables the system to have very deep extension and a tuning of around 12Hz while utilizing a 10" diameter port. This system was designed some years back in an effort to produce a system with full power output down to 10Hz and to assess the performance of the port system employed. The port design was borrowed from Polk Audio – a patented design from the nineties called the power port that is supposed to allow a controlled and constant expansion at both port ends allowing for greater air speeds before compression while also allowing the use of a shorter port length for the desired tuning. Nathan Funk of Funk Audio was commissioned to build the enclosure design and no expense was spared on the materials, build or finishing. This system demonstrates tremendous low end SPL, but has mediocre upper bass output as a result of the XXX 18 driver’s very low sensitivity. The power port system works very well with huge masses of air moving through the port into the room with barely a hint of chuffing at full output. Unfortunately the added complexity and design time required for this type of port limit its use. This is the first system tested by Data-Bass to provide in excess of 100dB at 10Hz at 2 meters outdoors. A simply massive 114dB was recorded at 12.5Hz under the same conditions which further confirms the visceral room shaking power this system possesses once inside of a typical room.
  4. #49
    Dec 2007
    Canada
    74
    7 Post(s)
    I changed my mind about going IB. Too much work to support the sub. I'm now thinking about doing a rear firing sealed box. This sub looks promising in sealed. Here's a vid I found: RE Audio XXX 15 underpowered 1500 RMS. Sealed - YouTube
    I see in one of your other threads you are thinking of giving up on the XXX in car. I'd say try sealed.
  1. RE xxx 15, or Adire Brahma 15 mk2
    By Denial in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-26-2005, 07:28 PM
  2. WTB RE XXX 15 OR Brahma 15
    By lslugz in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-21-2005, 09:55 PM
  3. Replies: 20
    Last Post: 07-27-2004, 02:10 AM
  4. ported or sealed for 15" xxx
    By w00t w00t in forum Enclosure Design & Construction Help
    Last Post: 06-15-2003, 10:00 PM
  5. 15" l7 better in ported or sealed box???
    By kixazz2529 in forum Subwoofers
    Last Post: 07-08-2002, 05:03 AM
