Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
Reload Thread: RE XXX 15: sound quality build; ported or sealed
  1. #16
    mugen08's Avatar
    mugen08 is offline Win aplenty
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Re: RE XXX 15: sound quality build; ported or sealed
    What makes the old xxx better?
  2. #17
    mugen08's Avatar
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Quote Originally Posted by Buck View Post
    OP what kind of music do you want to bump to?
    Rap, techno
  3. #18
    bumpasauras's Avatar
    bumpasauras is offline Always Hurtin Ears!!
    Feb 2009
    West. TEXAS
    436
    97 Post(s)
    Nothing wrong with that ap amp at 4 ohm. It won't clip unless you get greedy with the gain and powa is powa as long as it is not clipping. As far as the box I built a 3.75 ft/3 net tuned at 30 htz and good god almighty it would get low and hammer all through the freq range I had it on a apsm at 1 ohm and it did very well had a lil peak aroun 40ish htz but all the same it sounded great on the ap amp although I did have the gains on the amp consertive.
    1 other thing is make sure u built the box with atleast 3/4 mdf and brace the shizz outta it and double your front wall thickness. Make sure you liquid nails the crap outta it (even though your car will smell like a construction site for a month or 2) use lotsa screws and countersink/piolet drill everything. That's a whole bunch of mass moving back and fourth even with "only" 2k on the sub.
    Prolly already know all this just sayin.
  4. #19
    Silver-N-Black's Avatar
    Silver-N-Black is offline CarAudio.com Elite
    Aug 2007
    SoCal
    1,666
    3 Post(s)
    330 Post(s)
    Quote Originally Posted by mugen08 View Post
    XLB2 and the **** motors.
    Coming soon!!!!!!!!!!!!!!!!!!!
    Bought From : CrazedCat, motley, the727kid, JJones, TheLow, adas, Goindeaf, Reflecting,93dakota
  5. #20
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Rap, techno
    Do ported.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  6. #21
    mugen08's Avatar
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Quote Originally Posted by Silver-N-Black View Post
    Engrish prease
  7. #22
    glitchsta's Avatar
    glitchsta is offline Member
    Jul 2012
    Longmont, CO
    36
    56
    20 Post(s)
    I bought an 02 XXX recently off craigslist for $120, one of the four voice coils didn't register on the multimeter though I did wire up 2 of the 4 1ohm voice coils to 2ohm, threw it in a 3^3 box tuned to 26hz and the thing is so sick. Before this the best subwoofer I have had is 2 12" Shok Industry Tritons, which blew away my 2 12" Infinity reference subs. Even running 2 of 4 voice coils at 1500 Watts on the XXX, it hits the lows so much nicer than anything I have had before. I used to believe in budget cheap as can be setups, but now I am addicted to car audio and I am convinced the only way to do it is high power and high quality. It is totally worth buying the $300 subwoofer that will blow away two $100 subwoofers. I plan on getting my XXX reconed at either PSi or Fi...not sure which...I guess which ever has the best deal =] Time to figure out some components....oldskool RE kicks my *** though, is the point
    18" Custom 02' RE XXX xbl^2 motor w/ SPL Audio Corey Dean ReCone @ .5ohm / 4.5 Cube Built Box @ 30hz
    C&D AGM Battery - Front / NorthStar NSB110FT Battery - Back
    Vifa XT25SC90-04 1" Dual Ring Radiator Tweeters
    Digital Design CS6.5 - Front Doors /Silver Flute 6.5" - Back Doors
    MB Quart ONX 1.1500D 1x1500w @ 1ohm
    Zed Audio Leviathan v1 - 6x250 @ 2ohm / 6x150 @ 4ohm
    Execution Audio 0ga CCA / KnuKonceptz 4ga OFC / Shok Industries 12ga & 16ga FW Silver Coated Core Speaker wires
  8. #23
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    I see what you are saying, but that sub won't use that xmax in any box. And a lot of it has to do with the split coil not handling power as well as it should to even achieve those levels of excursion.
    It'll handle enough power and do it in home audio in a large bo (9-12 cubes for the 18 sealed), but your right, any box that fits in a car won't likely be effecient enough to use the xmax, especially if he's playing real music through the thing. I really would never use one of these in a car period, but if I did I still couldn't port it in good conscience.
    Also to OP, this sub is going to be peaky no matter what box you use it in if you want to get any output out of it. The split coil design is ALOT of metal and that leads to very high inductance, these things fall flat on their face above 60hz, just like the older xxx's tended to do.
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  9. #24
    T3mpest's Avatar
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    Engrish prease
    XBL^2 is a low distortion motor topology utilizing a grooved top plate to redistribute the flux field in a such a way that as the coil and motor keep a BL value that is at least 70% of it's value at rest over a longer distance than is feasible with a standard design.
    lol, I'm screwing with you man.. XBL^2 basically means the woofer can move further with less distortion than a regular subwoofer design. So they tend to be very good at SQL.
  10. #25
    mugen08's Avatar
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Sealed it is. Thanks.
  11. #26
    mugen08's Avatar
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    For all the new xxx haters:
    http://reaudio-rus.ru/reviews/review_xxx.pdf
  12. #27
    mugen08's Avatar
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Has this been tested? I have seen videos where the sub was obviously at 4" peak to peak excursion....
  13. #28
    soloXgt's Avatar
    soloXgt is offline Dinkum Flicka
    May 2007
    Buffalo/Rochester NY
    2,441
    51 Post(s)
    they aren't saying the new XXX is garbage, just not what it used to be
    HU: AVIC-F90BT
    Sub: 15" Treo SSX
    Amp: MTX TE4001D
    Front: Eclipse SC 8365 x 2
    Amp: Audison LRX 250.2
    Quote Originally Posted by jmanpc View Post
    JL attracts hood rats
    Quote Originally Posted by Lugnutz View Post
    It has to do with evolution. The blacks have not yet fully evolved from monkey to the current white human. They are in a transition state. That is why they are not very intelligent and have barbaric instincts that cause them to commit crime. It is just the monkey in them.
    REFS griffin850, Safe_Cracker, Kamikazekyle05, Korn4Life, blaze383..others on ROE also
  14. Likes I.v liked this post
  15. #29
    mugen08's Avatar
    Dec 2008
    Outside the box
    1,028
    20
    143 Post(s)
    Quote Originally Posted by soloXgt View Post
    LOL at the second part of your sig..
    So basically they used to have a more linear frequency response, but less SPL; the new ones get as low, hit harder, but are more peaky... I don't see how that makes them inferior all together, just in the linearity aspect... Depends on what you are after.
    Anyways, here is some extreme excursion in a sealed box; I don't see where some people get their info (They don't have enough motor for full excursion)... RE XXX 12 RACK CITY - YouTube
  16. #30
    I.v's Avatar
    I.v
    I.v is offline Member
    Apr 2013
    El Paso tx
    89
    24 Post(s)
    I love my xxx , re fix the teansel and voice coil problem they now use complete vc not the split one
    06 Trailblazer ss
    2 shok industries tsx 18s
    db drrive [email protected]
    db drive 125.4
    Re audio 6.5 components
    rf 8" pro audio
    re audio bass processor
    4 xspower d6500
    kenwood ddx714
  1. RE xxx 15, or Adire Brahma 15 mk2
    By Denial in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-26-2005, 07:28 PM
  2. WTB RE XXX 15 OR Brahma 15
    By lslugz in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 07-21-2005, 09:55 PM
  3. Replies: 20
    Last Post: 07-27-2004, 02:10 AM
  4. ported or sealed for 15" xxx
    By w00t w00t in forum Enclosure Design & Construction Help
    Last Post: 06-15-2003, 10:00 PM
  5. 15" l7 better in ported or sealed box???
    By kixazz2529 in forum Subwoofers
    Last Post: 07-08-2002, 05:03 AM
