Page 8 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 106 to 120 of 151
Reload Thread: nkrell11's Free Enclosure Designs & Cut Sheet To Whoever Wants One
  1. #106
    Nutdawg651's Avatar
    Nutdawg651 is offline CarAudio.com Elite
    May 2013
    1,414
    1 Post(s)
    479 Post(s)
    Re: nkrell11's Free Enclosure Designs & Cut Sheet To Whoever Wants One
    Quote Originally Posted by nkrell11 View Post
    @Nutdawg651 ;
    4 SA-12's 6.05ft^3 35Hz 9.35in^2/ft of port area 14in Aero's. You'd need to play with the woofer placement but this should work.
    This is what dbeez told me about this box
    Quote Originally Posted by dbeez View Post
    I recommend a 6" aero per 12 I feel box needs to be a bit bigger now I see why everyone says sa subs are louder in higher frequencies that small a box will causee a peaky box.
  2. Likes dbeez liked this post
  3. #107
    alec14's Avatar
    alec14 is offline CarAudio.com Elite
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    I have one To do for a single ia dp but I think I can get yours in tomorrow as well. Did you have a tune in mind I know most sq/aq subs are supposed to have higher tunings like 35-40hz don't know if you can run them lower or not.
    Sounds good man, thank you. and 35 would be great
    Bought from: flastrongman, nitefury 360, luckyderder, Jayzbent, fasfocus00, flaboy22, oldschool4me, Chevy Blazin', Inter007, dross93ranger, 04murdalanche, glitchsta, photocrazy8, 2002XLT
    Traded with: mylows10 Sold to/traded with: garychoffman, juanmgarza, 04murdalanche, Markyg66, basswiigee, btolenti, supereikenator, shauncox26, eg9(x2), big scott, bad @SS chevy
    http://www.caraudio.com/forums/itrader.php?u=1018999
  4. #108
    nkrell11's Avatar
    nkrell11 is offline CarAudio.com Elite
    Oct 2012
    Mt. Pleasant, MI
    748
    3 Post(s)
    197 Post(s)
    Quote Originally Posted by alec14 View Post
    Busy with any designs right now? If not and you have the time, I'd greatly appreciate a design that I need. I'm doing 3 Soundqubed sdc 2.0 8's, in a slot ported box. They'll all be wired to 2.6 ohms, with around 500 watts going to them all together for now. Max dimensions are 37" wide, 14" tall, and 15" deep. Here's a link to the subs: https://www.soundqubed.com/NEW-Stree...ofer_p_69.html
    If you need any more info, please let me know. And thank you again!
    Car:2004 Grand Prix
    H/U:Clarion CZ702
    Wires: 6 Runs Electron Beam 2/0
    Batteries: Juicebox Lithium 40ah
    Amp: Flatline 7k
    Substage:Custom Fi N3 15's
  5. #109
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    748
    3 Post(s)
    197 Post(s)
    Car:2004 Grand Prix
    H/U:Clarion CZ702
    Amp: Flatline 7k
  6. #110
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    35 would be great, thank you
  7. #111
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    748
    3 Post(s)
    197 Post(s)
    Quote Originally Posted by Nutdawg651 View Post
    Doesn't surprise me that much the constraints that were given to me didn't leave many options a slot port would have been better but I did what he asked and with the power that he had the larger volume could have caused problems.
    Alright I have one drawn up for you that I'll hopefully have uploaded by tomorrow.
    Car:2004 Grand Prix
    H/U:Clarion CZ702
    Amp: Flatline 7k
  8. Dislikes dbeez disliked this post
  9. #112
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    sounds good man, I'm really excited to see it. Thanks! If it'd be easier to send through text or email, just let me know
  10. #113
    Notabiker's Avatar
    Notabiker is offline Junior Member
    May 2013
    Anchorage, AK
    Quote Originally Posted by Notabiker View Post
    Hi, a guy I worked with gave me a pair of Sony Xplod XS-GTX120LW 4ohm svc when he left the state. I can't seem to find specs on the sub for air space but similar sony's like 1.13 cf ported. I'm looking at getting a RF Rockford Fosgate R500-1D Prime 500 Watt Mono D-class Amplifer which should put out about 250rms into the sub (only using 1 12" in the pickup and the other in a old car for the wife, but that comes later). Looking for SQ with an occasional foray into some 80's or 90's rap. I am hoping you can help me figure out a box for behind the drivers seat of my Nissan Frontier King cab.
    Looking for a ported box of the slot variety. I've got a table saw and know how to use it so 45's are no big deal. Also I will be using birch plywood as it's leftover from building a bookshelf and I never built a 2nd one or returned it to the store. It's about 18mm thick or .706" (not sure what the fractional is off hand I just used a caliper on it)
    Rough space to work with is
    14.5" bottom depth
    16" tall
    21" wide
    9.5" top depth
    I'm thinking of having the sub and bottom face 2" up from floor with the port firing forwards at the top of the sloped face. The box can go taller by following the same angle. Any help is appreciated as the only other times I ported my boxes I just called PPI up and they told me what the 4 12" pro's needed and I cut the pipe up.
    Hey nkrell11 if you are game I still haven't messed with these at all. No amp yet either but I'm back to work in a few weeks so I'll have money to play again.
    Thanks either way Sir
  11. #114
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    748
    3 Post(s)
    197 Post(s)
    @alec14 ; AQ SDC 2.0 8's 2.5ft^3 Net 35.23Hz 15in^2/ft of port area.
    @Reinhardt ; IA DP 12 2.2ft^3 33Hz 14.87in/ft.
    Car:2004 Grand Prix
    H/U:Clarion CZ702
    Amp: Flatline 7k
  12. Thanks Reinhardt thanked for this post
    Likes Reinhardt liked this post
  13. #115
    Nutdawg651's Avatar
    May 2013
    1,414
    1 Post(s)
    479 Post(s)
    Did you happen to make a cut sheet for the ia box?
  14. Likes Reinhardt liked this post
  15. #116
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    748
    3 Post(s)
    197 Post(s)
    No but I could tonight.
    Car:2004 Grand Prix
    H/U:Clarion CZ702
    Amp: Flatline 7k
  16. #117
    Nutdawg651's Avatar
    May 2013
    1,414
    1 Post(s)
    479 Post(s)
    How bout for both the ia and audioques i wanna see how both sound lol thanks bro
  17. Likes Reinhardt liked this post
  18. #118
    alec14's Avatar
    Aug 2012
    Alpena, MI
    1,818
    665 Post(s)
    Thanks man! What lengths would I have to add to make it 3 cubic feet net? And jw, what's a cut sheet?
  19. #119
    nkrell11's Avatar
    Oct 2012
    Mt. Pleasant, MI
    748
    3 Post(s)
    197 Post(s)
    Well the box would most likely need to be totally reconfigured as the tuning and everything would be affected by the change I just chose the middle recommended volume for 3 8's from the aq website. A cut sheet basically shows how to get the most out of a sheet of wood when cutting pieces for your enclosure there is examples earlier in the thread.
    Car:2004 Grand Prix
    H/U:Clarion CZ702
    Amp: Flatline 7k
  20. Dislikes dbeez disliked this post
  21. #120
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,427
    913 Post(s)
    Ok so your just going to the company website looking at what they say and go off that.
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire xs8k@.5
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
  1. Help please. Need a box design and cut sheet
    By boalova13 in forum Enclosure Design & Construction Help
    Last Post: 07-02-2008, 09:38 AM
  2. Need Box Design w/ Cut Sheet
    By Bossnup1000 in forum Enclosure Design & Construction Help
    Last Post: 05-06-2008, 06:22 PM
  3. design and cut sheet needed
    By bones22 in forum Enclosure Design & Construction Help
    Last Post: 05-06-2008, 12:52 AM
  4. Need Design And Cut Sheet Asap
    Last Post: 09-15-2007, 09:11 AM
  5. Bored and was wondering if anyone wants a free enclosure design?
    By danteBirosel in forum Enclosure Design & Construction Help
    Last Post: 01-17-2006, 01:42 AM
