Here is a box I just final prepped and painted for a customer.
Nice and clean. Definately a job well done. What kind of subs are going in that thing and what vehicle is it going into? How many hours did it take to do that work of art?
97 Monte Carlo
H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
The All Power Acoustik System (Removed)Amps(2) - Class D 3000watt (A3000DB)
Subs(2) - 15" MOFO 2600watt(MOFO-15)
Caps(2) - 2.4 Farad Digital Cap (PC2.4)
EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
Rears(1 Pair) - 4-Way 6x9's (XP2K694)
Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
DVD H/U(1) - DVD Player (PADVD610)
Box - 9 ft^3 box tuned to 35 hz.
New System Yet To Be Determined. Although It Will Be All MA Audio.
Thanks, its going in a mustang, I cant remember what kind of subs he had sorry. It took 3 days start to finish, buffed and delivered on the 4th.Originally Posted by monte_carlo97
I have tried to do some fiberglassing but none of my projects have turned out well. What kind of material did you use and how did you get it to form arround the curves so nice?
97 Monte Carlo
Is the bottom lip of the front right sub going to allow mounting? It looks squashed, but it could just be the picture. What paint did you finish it with? Looks good.
Is this not a reasonable place to park?
unless I used 3 gallons of clear " which I didnt" the speakers should still fit since the test fitOriginally Posted by Mark_ab
Duppont
Looks great, very nice paint. I saw some other stuff you painted and they all look great. I really dig that blue candy on the vw.
Thanks, lots more projects underwayOriginally Posted by fugit
Bookmarks
