Results 1 to 8 of 8
Reload Thread: 1/2" MDF
    Bodawg111's Avatar
    Bodawg111 is offline Member
    Jan 2004
    Longview, Tx
    21
    1/2" MDF
    Im about to build two underseat boxes for some Sony 10s to fit underneath the back seat of a 98-99 chevy silverado ext cab. Could I use 1/2" mdf to get as much air volume as possible or would it not be practical?
    Thanks
    Don't play leap-frog with a unicorn.
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    41
    7,770
    46
    1 Post(s)
    Re: 1/2" MDF
    if it's like under 300w, I guess so. If you turly want to maximise though, I strongly recommend that you try fiberglass.. they will be much thinner and stronger than 1/2" MDF.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    37
    8,477
    32
    Re: 1/2" MDF
    And the fiberglass supplies would cost more than his subs.
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    Bodawg111's Avatar
    Jan 2004
    Longview, Tx
    21
    Re: 1/2" MDF
    Id try fiberglass, but hes not paying jack crap. Oh well, 1/2" it is.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    31
    3,509
    Re: 1/2" MDF
    Quote Originally Posted by Bodawg111
    Thanks
    If you just running some sony's and want max airspace why not just use some good old cardboard and duck tape.
    J/K, The 1/2" MDF would work fine especially since you got sony's
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    Re: 1/2" MDF
    Quote Originally Posted by monte_carlo97
    I agree!
    Feb 2004
    Central Ohio
    31
    3,509
    Re: 1/2" MDF
    To tell you the truth though i have actually seen that done. All i could do was laugh my *** off until the guy was like what's wrong i thought it sounded really good. :hilarious
    97 Monte Carlo
    JnEsPappa's Avatar
    JnEsPappa is offline How's Ya Mom n 'Em
    Apr 2004
    Lafayette, LA
    48
    49
    Re: 1/2" MDF
    1/2" (5/8" probably) will be fine for your purposes. Try adding some braces from top to bottom to support the upper baffle for the subs.
  1. 3/4" MDF vs. 1" MDF
    By sumone in forum Enclosure Design & Construction Help
    Last Post: 02-28-2004, 07:39 PM
  2. Attaching MDF Baffle to Fiberglass box
    By gomerboat in forum Enclosure Design & Construction Help
    Last Post: 02-17-2004, 11:32 AM
  3. Can I get away with 3/4 inch MDF?
    By justsayk in forum Enclosure Design & Construction Help
    Last Post: 01-09-2004, 09:10 PM
  4. Ported XXX 12: Fiberglass vs MDF
    By CELLERBR in forum Enclosure Design & Construction Help
    Last Post: 11-06-2003, 08:13 PM
  5. Fiberglass vs. MDF Box
    By myowngod316 in forum Enclosure Design & Construction Help
    Last Post: 10-15-2003, 01:04 PM
