Results 1 to 15 of 15
Reload Thread: Fiberglass.....how do you make a bottom?!?!
    swimfreak26's Avatar
    swimfreak26 is offline I am cool
    Aug 2002
    East Lansing, MI
    3,132
    Allright, I'm ready to move into fiberglass but I can't figure something out. I see all of the tutorials molding fiberglass into specific areas, but none on how to create a free standing box.
    Basically I am planning on building a frame out of MDF, and stretching out fleece over that, and beginning the process, but as I think about it...I have no idea how to make the bottom of the box. I mean I see covering the sides and top, but how will the bottom be on...do I just wait for everything else to cure and then do the bottom, and sand out later?
    Thanks for your help
    Fuc, how come when I copy and paste **** it never gives me the cool blue thing in my sig. Sonofa*****withhotredtabascosauceonmynutz!!!!!
    References: g30ffr3y,Cjjackson85,Pearldrummer, Rattlebrain, Harrison486, excelerater, ax600, XtrmAudioCncpts
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    Re: Fiberglass.....how do you make a bottom?!?!
    Where are you planning on building this box? Generally, the bottom will be the mold you make, which will fit the contours of whatever you are molding it to. The mounting ring/baffle will be the top, and the fleece will be the sides.
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    Aug 2002
    East Lansing, MI
    3,132
    That's the conventional way to do it I know, but I am looking to build a "freestanding" box. In otherwords I am going for non-custom (as the word pertains to vehicle specifics) enclosure, that could be transfered into a new car if need be.
    So I will be building the box outside of the car completely....as I think about it though, if you do the "mold-to-the-car" thing then you're basically creating one side and then joining it with others (as the fleece is added) so would I just use the same concept?
    lay out a flat bottom
    glue frame to bottom
    fleece
    Continue on glassing
    obviously I'm leaving out some steps, but that's just to show the general idea I'm getting, does that make sense or would it not work? Also, how would I join the sides together without having unequalities?
    Again, thanks for any help
    Gauntlet's Avatar
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    Well, for what you want to do, why don't you leave the base flat? If you have some weird-shaped curved base, it's going to have trouble standing on it's own, much less be able to switch between vehicles. Build a basic frame out of MDF, be it a bottom and top, bottom and sides, bottom top and sides, or whatever. Then mount the baffle with dowels, add whatever shapes you want using wire mesh, chicken wire, pipe cleaners, etc. etc, stretch the fleece to fit around the baffle and curved areas, and then fiberglass it.
    - Slug
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    25
    11,175
    why dont u clear out your garage, lay some tape down on a flat part of your garage floor but alluminum foil over that, and take the edges down of the alluminum foil, spray some pam on the area u will be putting resin, resin that, let it harden, take it up, place your doyls, and do the "traditional" way
    Gauntlet's Avatar
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    Making a completely flat section out of fiberglass sort of defeats the purpose of fiberglass.
    - Slug
    Aug 2002
    East Lansing, MI
    3,132
    I'm going to have a completely flat section, but that will only be the bottom. My main question now I guess before I get started, is how do I join the bottom and the rest of the box when they will have to be glassed at different times?
    williams22's Avatar
    williams22 is offline Senior VIP Member
    Mar 2004
    Vermont
    174
    I dont understand why you wouldnt just use mdf for this box?
  9. #9
    Aug 2002
    East Lansing, MI
    3,132
    because MDF is boring...I've been there, and I want something much more clean looking, plus I just want the experience. Can anyone help with the issue though, how do you join, cleanly, two edges being glassed at different times?
  10. #10
    Gauntlet's Avatar
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    Just so you know, fiberglass is strongest in curved areas, so it's a big waste of time and money to do a flat area in fiberglass. As far as joining edges, just use fleece as you normally would. The clean look you desire is achieved through lots and lots of time spent on applying body filler and sanding it.
    - Slug
  11. #11
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Using Fglass is a waste of time and money for flat panels. But if you really want to the best way is to find an old piece of glass ( window ) spray it down with pam. Then get to glassin, Make sure you smooth it out real well, Then after one or two layers glass in some poly rope for strength. Then another couple layers of mat. Viola perfectly flat really strong fglass panels
    5 % equipment
    90 % install
    5% beer
  12. #12
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    31
    368
    im going with mdf..it may be boring, but nobody will see the bottom anyways... my box has 2 mdf sides just for keeping it flat
  13. #13
    Hondaluv's Avatar
    Hondaluv is offline Member
    Mar 2004
    Grande Prairie, AB.
    30
    34
    Jesus, mdf bottom, sides and back, mount your rings and glass the front over, universal but interesting.
  14. #14
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    32
    4,234
    make the bottom first, stretch the fleece over the frame and mdf rings, staple it on the bottom. then go to town w/ the glass. silicone it from the inside when your done.
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
  15. #15
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    26
    15,596
    22
    guys, this threads over 3 months old...
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
  1. fiberglass fitment
    By chopstick1981 in forum Enclosure Design & Construction Help
    Last Post: 01-16-2004, 09:15 AM
  2. ---READ---Something that would make fiberglass more fun for everyone!!
    By mayday0017 in forum Enclosure Design & Construction Help
    Last Post: 01-12-2004, 07:24 PM
  3. Mark, Ramos, Mike ... Fiberglass Port ?'s.
    By ss3079 in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 12:08 PM
  4. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
