Results 1 to 5 of 5
Reload Thread: 4 12" kicker comp design help
    weedy's Avatar
    weedy is offline Junior Member
    Apr 2013
    Naples, FL
    19
    I have a 2001 Chevy Silverado, Ext. cab. I want to put all 4 under the back seat, face down. I have a 1000 watt ssl evolution monoblock amp to power it.
    Questions:
    Sealed or Ported?
    would 4 be possible? if not two?
    8 g.a or 4 g.a wire?
    Let me know if anyone can help me sketch up a design for my truck. THANKS!!
    brandonkain82's Avatar
    brandonkain82 is offline your mom goes to college
    Dec 2012
    frankfort,il
    35
    728
    265 Post(s)
    Re: 4 12" kicker comp design help
    All 4 sealed with 4 gauge and you will be banging. Not enough room ported unless u build a wall. 2 ported will work.
    2 smd fifteens on 2 b2 m1s. 8 crossfire mids and 4 aq tweets on 3 b2 qautros. 270 mechman. 10 c and d batts. Busting windshields like its my job.
  3. Likes weedy liked this post
  4. #3
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    You can do two sealed down firing. I don't think you will have the room to go ported at all, or to fit 4.
  5. Likes weedy liked this post
  6. #4
    weedy's Avatar
    Apr 2013
    Naples, FL
    19
    Okay, another question, any way or refrence i can make a custom center console to house the other two or possibly one?
  7. #5
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    In theory you can, but you will likely run into issues with attempting to get the settings right on the amplifier. The reason being that each set of subs will be reacting different do to the difference in enclosures.
    However, if you match the volume in the console and down fire the console sub(s) the same distance from the floor as the under seat enclosure you might be able to make it work.
  1. 2 12 inch Kicker comps dont hit hard ( help )
    By rayy166 in forum General Discussion
    Last Post: 10-07-2012, 11:55 PM
  2. NEED HELP! 2 12 inch Kicker comp + sony xplod amp
    Last Post: 10-01-2012, 02:32 PM
  3. Kicker Comp VRs, help me solve this VC debate
    By nweibley in forum Wiring, Electrical and Installation Help
    Last Post: 02-08-2004, 09:58 PM
  4. slot-ported box plans needed for 12 inch kicker comp vr
    By Scarface in forum Enclosure Design & Construction Help
    Last Post: 01-30-2004, 02:00 PM
Tags for this Thread
