Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 65
Reload Thread: need amp ideas for 4 sundown audio sa-8 v2
  1. #31
    skippy90210's Avatar
    skippy90210 is offline Member
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    Re: need amp ideas for 4 sundown audio sa-8 v2
    is there anyone that could design a box for me that would run the 4 subs? i could build it if i knew what to build
  2. #32
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    yes i am limited on space also all the kids around here are all about 12's and i want to show them 8's can get the job done lol but its mostly space issue
  3. #33
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    is it possible to wire 4 dvc 4ohm subs to 1 ohm?
  4. #34
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    if not would 2 saz1500d amps and run 2 subs wired at 1ohm on each amp work well?
  5. #35
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    Quote Originally Posted by skippy90210 View Post
    no 2 ohms or .5 ,i have 4 vfl 8's under my rear seat in the z71 truck on 2600 rms and they get pretty loud .you need at least 2600-3500 rms for those subs.i see that you prefer a new amp as well .well dc is having a presale on some of they're amps which will be shipping out the 1st week of march .i can give you a good deal on a new dc 3.5 amp ,and its under the budget that you stated earlier .
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  6. #36
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    im not doing the system right now so thats why a new amp would be easier for me im going to be doing it in a couple of months so you think 2 saz1500 would work fine just run 2 subs on each at 1 ohm
  7. #37
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    also is there a benifit to run at 1ohm?
  8. #38
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    would it be a good idea to get 2 cheaper amps of higher watts since cheap amps are like not true like say get two boss 5000w amps or i found this power acoustik amp its rated at 2200 at 1ohm so run 2 subs off of that half of 2200 is 1100 and it wouldnt be true wattage since its a cheaper amp wouldnt it be at like 750w to each sub?
  9. #39
    RicksI30's Avatar
    RicksI30 is offline CarAudio.com Elite
    May 2011
    Tucson, Az
    29
    588
    189 Post(s)
    No
    Head unit: Kenwood Excelon KDC-X996
    Front stage: Alpine Type X PRO mids Vifa Neo 1" silk tweeters
    Front stage amp: PPI Bk800.4
    Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
    Sub amp: PPI Bk1300.1
    Sound Deadening: Second Skin Damplifier Pro, Spectrum, and Sludge
    Team SSA
  10. #40
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    what would be actual wattage on an amp like that?
  11. #41
    sbarber82's Avatar
    sbarber82 is offline CarAudio.com Elite
    Dec 2012
    Vegas baby
    35
    520
    162 Post(s)
    I am running 4 sa8v2's on a ampere audio 3500.1 prototype. The amp will be available to the public in a couple months max.
    Ride:2009 Silverado Crew Cab
    H/U: Pioneer avh-p4400bh
    Amps: Ampere Audio 3800.1 Ampere Audio 125.4
    Subs: 2 Tantric HDD 15's
    Enclosure: 4th Order Blow Through
    Mids/Highs: Tantric HD
    Singer 320 Hairpin 6 phase
  12. #42
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    what would be the best budget amp to make the 4 8s hit decent until i got good amps because im gonna put all my money into the box and the subs themself im not gonna have much for amps
  13. #43
    sbarber82's Avatar
    Dec 2012
    Vegas baby
    35
    520
    162 Post(s)
    Anything 2k or so would be fine. Find a good deal on a used 2k amp then buy a 3500 when you have the money saved. I will be able to get you a Ampere Audio when they are available if you like. Great Zenon based amp
  14. #44
    Feb 2013
    ramey, PA
    147
    76 Post(s)
    the only thing is cheap amps usually dont give out the wattage they say they do so what the best bang for the buck brand or the best like off brand amp that will give me close to the wattage it says?
  15. #45
    sbarber82's Avatar
    Dec 2012
    Vegas baby
    35
    520
    162 Post(s)
    I meant find a used amp on here by aq, powerbass, american bass, sundown,etc that is 2k and cheap. You should be able to find one of those on here or on caraudioclassifieds.com for a good price!
  1. What amp to get for 1 Sundown Audio SA-12?
    By leglez in forum Amplifiers
    Last Post: 08-06-2012, 01:07 AM
  2. FS: 3.5 @ 32 HZ for Sundown Audio SA 15
    By Argent Audio in forum Miscellaneous Car Audio Classifieds
    Last Post: 06-27-2011, 05:35 PM
  3. Need some ideas for fiberglassing 4 10s and 2 amps...
    By rollininstyle04 in forum Enclosure Design & Construction Help
    Last Post: 06-09-2005, 09:55 AM
  4. Amp for JL Audio 12W3 v2
    By WDunn28 in forum Subwoofers
    Last Post: 03-23-2005, 10:41 AM
