Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
18 fi btl n2 box design for trunk.
Im needing help deciding what i wanna do. I currently have a american bass 200.1 a matrix 2 c&d batteries in trunk. 2 runs of 0g to trunk+1 4g for matrix and 4 channel. Big 3 is done as well. 180amp alt. Anyway im debateing on doing a aeroport this build but dont know what size to go with. Can anyone help me out with a nice box desihn or give me some ideas. Thank you
Re: 18 fi btl n2 box design for trunk.
Im getting a sp4 man.. FI make the best subs man.
Low & Loud Songs - Slowed By BenBen Vol 1: http://www.sendspace.com/file/328is7 -
Low & Loud Songs - Slowed By BenBen Vol 2: http://www.sendspace.com/file/vq6pdx
***Current Setup***
2006 Pontiac G6 Sedan
Pioneer avh-p4300 Head Unit
FI Sp4 15 (D1.27 ohm)
3.5Cu Slot Ported Box tuned to 33 Hz (Designed By @dbeez )
Sundown Audio Saz 3000D
Originally Posted by
-BenBen-
Ive never owned one before so hopefully i like it. Im sure i will.
bro im telling you.. i have had hdc 3, xfls, 9500s,type rs,ect.. the btl is nasty. tuned to 29 hz..amazin, hits high notes crazy well and murder lows.
***Current Setup***
if you can squeeze 4.5 - 5 cu, thatll be good but tun between 28-32. i would do aero port side fire with sub forward if your seats fold down
***Current Setup***
I can slide up to a 7cu box in trunk with sub up. I do plan on haveing custom box made so sub fires into csr.
For daily application what would be better slot port with sub up. Or aero port and sub faceing into car or sub in car port out the side.
i'm halfway done building a box for a Fi 18BL.
square port tuned for 45Hz for SPL.
rectangular port is tuned for ~30Hz for normal use.
Plugs will be made for both and the 45Hz will only be used for comps.
have you been helped by me? i'd love to know. shoot me a PM.
My 2001 Accord build log:
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
Can I help you? valencebandacoustics@gmail.com
Want to learn about car audio electronics?
http://www.bcae1.com
I prefer sub/port firing into car. I do oversized ports with a port reducer for daily & metering....
Yea i gotta build box in trunk or build a 2 piece box... Whats a good sized aero port to use. 8in 10in. 2..6in 4 4inch. I have no clue about aero ports. But im learning
Loud, efficient and in a Honda trunk
By fisubsaregross in forum Enclosure Design & Construction Help
Last Post: 08-31-2011, 01:55 PM
By lambofgood91 in forum Enclosure Design & Construction Help
Last Post: 06-25-2008, 03:16 PM
By babaganoush123 in forum Enclosure Design & Construction Help
Last Post: 01-02-2008, 06:08 AM
By jbamaboi36116 in forum Enclosure Design & Construction Help
Last Post: 08-27-2007, 09:09 PM
By Wragold in forum Enclosure Design & Construction Help
Last Post: 05-04-2007, 04:14 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
