Results 1 to 5 of 5
Reload Thread: 2 DC Level 4 15" Enclosure Ideas
    Samwatts22's Avatar
    Samwatts22 is offline Junior Member
    Feb 2013
    Brampton. Ontario
    I just bought 2 DC level 4 15"s and I am having trouble with deciding what type of enclosure to put them in. I'm pretty set on 3.5-4 cuft per sub at a 30-32 hz tuning. Not sure on the following
    Aero port vs. Slot port
    Subs up/port rear vs. subs up ports up
    I'll be running them in a Dodge Magnum SXT so space is not limited to 3.5 per.
    any ideas or suggestions are greatly appreciated!
    * Dual 2 ohm, running off 2 seperate xtx5000.1 Re Audio Mono's ( non Bridgable sadly.) Amps are already owned so please dont ream me on how it turned out i bought with the intension of running 1 xxx 15 and 2 dc level 2 12"s but it didnt work out to be that way so now on to the box ideas please and thanks!!
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,164
    6 Post(s)
    2220 Post(s)
    Re: 2 DC Level 4 15" Enclosure Ideas
    I think for those subs stick to around 3-3.5 cubes net per, tuned around 32. Sub up, port back. Slot vs Aero is up to you.
  3. Likes Samwatts22 liked this post
  4. #3
    Samwatts22's Avatar
    Feb 2013
    Brampton. Ontario
    Any Pro's and cons on running slot vs. aero on 15"s?
    and thanks I think i will be keeping it at 3.5 and 32-31Hz
  5. #4
    mklett33's Avatar
    mklett33 is offline Senior VIP Member
    Nov 2008
    MI
    417
    61 Post(s)
    Aero ports are allegedly more efficient for their cross sectional area, and have the advantage that if you do not like the tuning you can quickly change them out. Slot ports allow for part of the port being part of the enclosure itself, thus serving dual purpose, done properly either one will satisfy. Personally, I have always done slot, but I am partial to kerfing, and its just the way "I've always done it"
  6. Thanks Samwatts22 thanked for this post
  7. #5
    Samwatts22's Avatar
    Feb 2013
    Brampton. Ontario
    Thanks big help i think i am going to go with the slot port. Hopefully add some rigidity to my enclosure
  1. DC Audio Spring Build Enclosure Ideas
    By Bostonjlguy in forum Enclosure Design & Construction Help
    Last Post: 12-28-2012, 10:42 PM
  2. enclosure specs for a 15 inch DC level 4xl
    By mendezm9 in forum General Discussion
    Last Post: 05-03-2010, 10:45 PM
  3. wtb: dc level 3 15"
    By bassboobs16 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 09-16-2007, 09:58 PM
