Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
2 MMAT procasts design?
Would this work? Sorry for shitty design, at work...
@Buck ; @double 07 ; @pro-rabbit ; @TaylorFade ;
Current set up: 2010 Buick Enclave, 2 12" MMATS PROCASTS 2.5@35, MMATS D200HC
Hertz 165XL comps in front door, Eclipse XA4000(switching to Alpine 1507)
Pioneer Z150bt Nav, Audio Technix all around.
66 Pontiac GTO, modified stock radio, Xtant 3150x, Trubass 8", Kicker KS6.5's in the front kicks.
Feedback...http://www.caraudio.com/forum/showthread.php?t=287960&highlight=ace_800
Re: 2 MMAT procasts design?
Looks like you are wanting a more SPL style port and then another more daily port the slides it in. If that this the case, then yes, that idea will work. I didn't do any math to check tuning or anything...but the idea works.
Originally Posted by
pro-rabbit
Correct, I'm getting 4.9^3 from the12volt off those specs and with a 5" port @48hz would be 9.3" and 2.5" port @34 for be 11.25"
What are the port hxw? Seems rather small for port area.
I'm good with it. I wonder why more people don't do this, actually.
TaylorPro has an interchangeable port. I can't recall exactly how much louder the SPL alignment is, but it's significant. Funny thing though... his SPL port actually peaks lower than his daily port. But it's still louder. Why? Impedance rise.
I've said it about 9,473 times. You don't tune to a specific freq. You tune for impedance rise. You vehicle is going to peak where it's going to peak. I don't understand why people feel the need to force it to a specific frequency when they could be missing out on thousands of watts by doing so.
But having an interchangeable port, testing will be easy. Do the daily where you want it and don't get hung up on the "tune" for the SPL one. Just test different sizes and lengths until you find your sweet spot.
eCrack
TaylorFail
Suicide Bobb
Taylorfail, v.2
Imtjnotu
tailorFail v.3
brodeisel
TaylorFail v.4
tat2bass
TaylorWin v.1?
By chapy4650 in forum Subwoofers
Last Post: 05-28-2002, 10:27 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
