Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Reload Thread: I joined this site to ask this question...
  1. #16
    billsburgundy's Avatar
    billsburgundy is offline Junior Member
    Jan 2013
    Winnipeg, Manitoba
    4 Post(s)
    Re: I joined this site to ask this question...
    AV83.....ok riddle me this then...lets says it IS a large flat panel...and lets say the fiberglass was a centimeter thick and YOU were trying your best not to mess the fiberglass up....would you choose a sealed box in a sealed trunk, sealed box in an open trunk, vented box in a sealed trunk or vented box in an open trunk?
  2. #17
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by billsburgundy View Post
    It's dependent on what subs and how much power are you putting on them? Ive seen two twelve's sealed make metal panels go nuts. but I wouldn't feel safe even driving a car that couldn't handle a system out of fear of breaking/cracking it. If it can handle vibrations caused by everyday driving without cracking up , it can handle some bass.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  3. Likes audiobaun liked this post
  4. #18
    Jan 2013
    Winnipeg, Manitoba
    4 Post(s)
    ok. and now ill be honest with you...this is a purely cosmetic issue...I think it looks stupid when you see someones car trunk shaking and physically moving but I do love a lot of bass. it's about 1000 watts RMS per sub. the fiberglass is quite sound and the car is safe I just want to be able to crank it a bit and not have it look like trash from the outside while driving...I dont care about rattling i just dont want it to be seen.
  5. #19
    akadj's Avatar
    akadj is offline Senior VIP Member
    Apr 2004
    Edmonton Alberta CANADA
    40
    458
    161 Post(s)
    Quote Originally Posted by UnderFire View Post
    I'm assuming behind the back seats you have a large hole? if so, this is what I mean.
    The box is port and subs firing forward, into the cabin, completely sealed off from the trunk itself.
    x2 or 3.. or what ever the score is.. but because the trunk isnt flexing anymore probably means now your doors and roof will flex and vibrate. . or as you say.. "trash look"
    you need sound deadening as well
  6. #20
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    pics of vehicle?
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
  7. #21
    av83's Avatar
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Then face the subs (and port If you have any) forward into the cab. you'll lose some of the low frequency response, but you shouldn't have much trunk flex. But, tbh, 2000 wrms is going to equal body flex somewhere. You are going to have to do some bracing and such to prevent the roof from having the same problem if you have them firing into the cabin. I'm pretty sure cld tiles, dynamat, etc won't help with fiberglass as much as they would with metal, either.
    80prs
  8. #22
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    to get a serious answer you need to share pics of the vehicle and space available. a generic answer to a generic question is not going to be very useful. it would also be helpful to see what you currently have that you are not happy with. getting good bass out of a sub system is heavily dependent on execution.
    high SPL will pressurize the cabin/trunk and something will give. if the vehicle is not air-tight, then that pressure release will alleviate some of your concerns, but can also tune the cabin as a bandpass enclosure.
    custom vehicle or not, fiberglass is much more stiff and stronger than the sheet metal of modern cars. if you want to ensure stiffness, glass some ribs on the larger pieces to enhance strength. but a concern for vibration is independent of vehicle strength. vibration is caused by two pieces vibrating against each other - such as door/trunk latches and body seams. doesn't matter how strong a singular piece is, it can still move in it's entirety in lieu of flexing in a wave-like motion. strength at seams/joints is independent of individual piece strength.
    just about any SPL can be attained with any combination of subs/sizes/quantity. how you integrate the sub(s) into the vehicle and how they are powered is key.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  9. Thanks av83 thanked for this post
  10. #23
    Jan 2013
    Winnipeg, Manitoba
    4 Post(s)
    thanks to everyone! vehicle is unfortunately in storage. I believe i will just dynamat trunk and use vented box. i dunno.
  11. Dislikes av83 disliked this post
  12. #24
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    not many trunk cars will fit 2 15's, so why is that your choice? Single 15 ported or 2 12's off the power you have should be fine.
  13. #25
    pickup1's Avatar
    pickup1 is offline CarAudio.com Veteran
    Aug 2005
    Roanoke,TX
    53
    8,467
    19
    7 Post(s)
    838 Post(s)
    Any pic of said fiberglass trunk panels?
  1. is this an okay site to buy this head unit off of?
    By jpd2621 in forum General Discussion
    Last Post: 06-08-2008, 04:43 AM
  2. probably the wrong forum to ask this but...
    By tcguy85 in forum General Discussion
    Last Post: 12-16-2007, 07:36 PM
  3. I shouldn't even have to ask this...
    By BringDaBoom in forum Amplifiers
    Last Post: 11-01-2007, 09:33 PM
  4. sorry to ask this wiring question?
    By 95Prober in forum Wiring, Electrical and Installation Help
    Last Post: 06-11-2006, 06:18 PM
  5. I really hate to ask this...
    By rollininstyle04 in forum Subwoofers
    Last Post: 04-09-2005, 12:09 AM
