+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Reload Thread: Ehh how do I find subwoofer displacment ?? And measure port ??
  1. #16
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    Re: Ehh how do I find subwoofer displacment ?? And measure port ??
    Quote Originally Posted by dedwardk View Post
    also that would help with port noise theoretically ?? cause when you use smaller box and crank it up it may give a whistle ??
    or is that what you meant by efficient
    sorry guys .. told u im rusty
    port noise has to do with the size of the port or obstructions in the airflow through the port.
    I'm no expert by any means but from what I understand, efficiency of large boxes come from allowing the woofer to reach xmax sooner than in a small box, given the same amount of power. I also think that large boxes rise less through the impedance curve, but there are others that say that smaller boxes have less impedance rise, I don't have the equipment.... yet, to test that theory.
    13 Dodge Dart Rallye 1.4T
    DD 2515 Supercharged
    RF T1500bdcp
    Audiotechnix wire and deadening
    http://mobileaudioforum.com/forum/forum.php
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
  2. #17
    dedwardk's Avatar
    dedwardk is offline Junior Member
    Jan 2013
    Omaha
    Well thanks for your help and time !!
+ Reply to Thread
  1. How do i mount my amps and subwoofer box in my trunk?
    By imbored408 in forum General Discussion
    Last Post: 11-29-2011, 03:52 PM
  2. how do i find out the lenght of port?
    By brmcm15 in forum Enclosure Design & Construction Help
    Last Post: 09-27-2008, 03:52 PM
  3. How do I find the port length and diameter using pvc?
    By ace_800 in forum Enclosure Design & Construction Help
    Last Post: 03-23-2007, 08:32 PM
  4. how do i find port area and displacement
    By skmfkr in forum General Discussion
    Last Post: 10-17-2005, 06:07 PM
  5. How do you find box volume after displacement??
    By BIGGUP21 in forum Enclosure Design & Construction Help
    Last Post: 07-21-2003, 08:05 PM
