Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: RE XXX 12" Box almost done..
  1. #16
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    Re: RE XXX 12" Box almost done..
    Looks sick bro
  2. #17
    esmokah's Avatar
    esmokah is offline Dabbed Out
    Apr 2011
    North of 8, WI
    380
    113 Post(s)
    Thanks guys. it was a fun project and i'm glad that is over. I have some other things to do on my car before I get it loaded in there.
    Head Unit: Pioneer avh-4300dvd,
    Front Stage: Ascendant Audio 6.75", Massive Audio 28mm tweeters
    Rear Fill: Massive Audio CK6-3 6x9 Woofers
    Amps: PPI Phantom P900.4, Sundown Audio SAZ-2500D
    Sub: RE Audio XXX 12" 2.25^3 Tuned to 32
    They sell Kicker at Wal-Mart now. That's saying a lot..
  3. #18
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,195
    1900 Post(s)
    Looks good
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  4. #19
    esmokah's Avatar
    Apr 2011
    North of 8, WI
    380
    113 Post(s)
    One of my speaker leads ended up being short so i had to rotate the sub a bit. I'll fix it later once I'm back from my trip. I still need to make some pleather lined foam pieces to fill the gaps on the side. It's coming together!
  5. #20
    eddie_93's Avatar
    eddie_93 is offline Member
    Jul 2012
    Western Wisconsin
    25
    146
    1 Post(s)
    33 Post(s)
    Quote Originally Posted by esmokah View Post
    Turned out sick man! Good work.
    Kenwood Excelon KDC-X494
    Sony Mobile ES XM-5046
    Image Dynamics CTX-6.5cs components
    8" Rockford P1 in .7 cubes, 3" PVC Aeroport @ 35 hz
    Bought from: SkarAudio Sold to: VanLan
  1. 03 RE XXX 12 Box Design - No Experiance
    By LGK in forum Enclosure Design & Construction Help
    Last Post: 05-22-2009, 02:33 PM
  2. BOx for 08 RE XXX 12" does this sound aright
    By jerod187 in forum Enclosure Design & Construction Help
    Last Post: 08-27-2008, 12:14 PM
  3. re xxx 12" with custom box
    By jpd2621 in forum Subwoofers
    Last Post: 04-28-2008, 11:15 AM
  4. re xxx 12 box specs????
    By TrickeffeX in forum Subwoofers
    Last Post: 10-28-2004, 03:51 PM
