Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Reload Thread: Aeroports or slots?
  1. #31
    mat3833's Avatar
    mat3833 is offline CarAudio.com Elite
    Mar 2008
    florida
    1,070
    232 Post(s)
    Re: Aeroports or slots?
    not sure on your car. but when i had mine set subs up ports side it was louder. but that was in a hatchback. sound reflected off the window and up to the front. not sure what you drive.
    and if you really want to go aero, you will have to have an "L" port for dual chamber enclosure
    Matt
    Star Mountain Nuthugger #5
    12" TC9 in 1.39 cubes @30hz
    Boston Acoustics GT-2300 @4 ohms bridged.
    Quote Originally Posted by double 07 View Post
    Sub cutout got a little skar on it...dad blamed round over bit bearing came flying off.......LOL.......
    Quote Originally Posted by gckless View Post
    A little Skar on it? Was it a B-stock bit?
    Refs:
    bought from Nitefury360, Tallic, SPLaudio X2
    Traded with Marleyskater420
  2. #32
    N9ne Millahhh's Avatar
    N9ne Millahhh is offline Junior Member
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    well the 6" aero is $40 so i might just go slot for now lol. its louder with subs and port firing back but I've never tried port firing side.
  3. #33
    OmegaBunny's Avatar
    OmegaBunny is offline Moderator
    Oct 2007
    Keyser, West Virginia, United States
    2,722
    464 Post(s)
    How much room total do you have for the width? I know 35" is for the box, but for you have like 38", 40"? You need to make sure that your port isn't too close to one of the walls.
    2007 Black Diamond FJ Cruiser with Box built by Pro-Rabbit
    H/U Kenwood DNX6960
    Sub: 1-18" Zv3 with NS coils and cone Sub Amp: Mmats 2100.2
    Front Stage: Hybrid Audio L6 mids, SEAS Neo Tweets, SAX 100.4, RF 3sixty.2
    Bought From: Rio, davidtemple, Bassin Buick, Pro-Rabbit, Kangaroux, KyleBechtold Traded With: WhiteDragon551 Sold To: jdmeklove, Kpozr2, 97accordalpine
  4. #34
    OmegaBunny's Avatar
    Oct 2007
    2,722
    464 Post(s)
    If you have the room you could do this....
    35(w)x18(d)x13(h) with (2) 4" aeros, subs back ports side. It should be just about 3.0ft^3 after sub and port displacement and bracing...
    internal dimensions: 33.5*11.5*16.5= 6356.625 / 1728 = 3.678 internal volume
    Sub displacement: 0.14 x 2= 0.28 (2 Subs)
    Port displacement: 0.168 x 2 = 0.336 (2 4" ports @ 23.16" long)
    Bracing: .034 and .05 = .084 (2x4x11.5 and 2x4x15.5
    Total internal volume: 2.978 ft^3 @ 30hz
    Just about...
    If my math is correct
    H/U Kenwood DNX6960
  5. #35
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    That looks like a good idea to me but i just found sonething out that will make money tight so i'm gonna go with an L-slot port.
    35"w by 13"t by 18"d with a 3.5" port and a second port length of 20". Am i on the right path?
  6. #36
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    i think like 45" total...but i'm just gonna go with 35" wide by 13" tall by 18" deep, 3" port width, 11.5" port height, 29.5" port total length.
    If i did it right, should be 3.079 ft^3, tuned at 29.63Hz, using the RE Audio Calculator, because i trust it, but anyone know where to put the sub displacement into account? do i just add it on to the box volume i want?
  7. #37
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    I haven't done the math, but re calc is not accurate. My other question is why are you tuning so low? Do you only listen to chopped and screwed music?
  8. #38
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    I got a box designed using torres and re audio as a start guide. And it'll be tuned to 30.5hz because i love low bass and with these subs the sound quality will be awesome. I love how 30hz boxes sound.
  9. #39
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Ok, I wish you goo luck with your build.
  1. Tube or Slot Port?
    By Psyence in forum Subwoofers
    Last Post: 07-18-2006, 10:26 PM
  2. Round or slotted
    By SlimShady16 in forum Enclosure Design & Construction Help
    Last Post: 04-22-2005, 02:33 PM
  3. Round or Slot Port???
    By BoomCrew in forum Enclosure Design & Construction Help
    Last Post: 02-19-2005, 12:48 PM
  4. Round ports w/ port noise or slotted vent?
    By pacho in forum Enclosure Design & Construction Help
    Last Post: 01-06-2005, 07:37 PM
  5. round or slot port
    By waNtsumBuMP in forum Enclosure Design & Construction Help
    Last Post: 08-30-2004, 07:06 PM
