Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 39
Reload Thread: Aeroports or slots?
  1. #16
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Re: Aeroports or slots?
    Quote Originally Posted by OmegaBunny View Post
    I like areo's in boxes but it would be nice to know how big he can go. If he has like 8ft of useable space he could go very big with the aeros.
    He he has the space available, I would just go with slot port in most cases. He will likely have an issue with the port length if he goes with a large amount of port area. That has always been a huge issue with them. Most enclosures are never more then 15-20 deep so that is rather limiting in port length.
  2. #17
    mat3833's Avatar
    mat3833 is offline CarAudio.com Elite
    Mar 2008
    florida
    1,070
    232 Post(s)
    for refrence im using a 3" aero for my 8" sub. 18mm Xmax, ~400W of power... 1.1 cubes with a 14" long aero
    Matt
    Star Mountain Nuthugger #5
    12" TC9 in 1.39 cubes @30hz
    Boston Acoustics GT-2300 @4 ohms bridged.
    Quote Originally Posted by double 07 View Post
    Sub cutout got a little skar on it...dad blamed round over bit bearing came flying off.......LOL.......
    Quote Originally Posted by gckless View Post
    A little Skar on it? Was it a B-stock bit?
    Refs:
    bought from Nitefury360, Tallic, SPLaudio X2
    Traded with Marleyskater420
  3. #18
    OmegaBunny's Avatar
    OmegaBunny is offline Moderator
    Oct 2007
    Keyser, West Virginia, United States
    2,722
    464 Post(s)
    He could fit longer ports if he went ports side sub back and did like a 16-20" deep box couldn't he. Something like 20"d x 35"w x ?(h). Of course you need to remember I'm not a designer lol. I guess it all depends on the area he has to work with and the desired results.
    2007 Black Diamond FJ Cruiser with Box built by Pro-Rabbit
    H/U Kenwood DNX6960
    Sub: 1-18" Zv3 with NS coils and cone Sub Amp: Mmats 2100.2
    Front Stage: Hybrid Audio L6 mids, SEAS Neo Tweets, SAX 100.4, RF 3sixty.2
    Bought From: Rio, davidtemple, Bassin Buick, Pro-Rabbit, Kangaroux, KyleBechtold Traded With: WhiteDragon551 Sold To: jdmeklove, Kpozr2, 97accordalpine
  4. #19
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    It is possible if he has the room for a side port.
  5. #20
    N9ne Millahhh's Avatar
    N9ne Millahhh is offline Junior Member
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    I have max dimensions of: 35" wide, 13" tall, and 18" deep. And i do want 3.0ft^3 @ 30Hz. I'm open to whatever designs would work, ex: single chamber, aeros, separate chambers, etc.
  6. #21
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    And i have 850w rms to each sub. If that matters...
  7. #22
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    you have 3.68 cubes to work with. using a single 6" aero 22" long will net you 3.09 cubes for your subs and give you 30.55hz tuning. add in the aero flares and you should be at or just below 30hz.
    Matt
    Refs:
  8. #23
    OmegaBunny's Avatar
    Oct 2007
    2,722
    464 Post(s)
    Is the 35" total width or does that leave room on the sides? If it leaves room then how much?
    H/U Kenwood DNX6960
  9. #24
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    oh, and i used .2 cubes as sub displacment. forgot to take into account bracing. so you may end up with slightly less than 3 cubes and have to add an inch to the aero. but im sure someone will factor all that in.
    Matt
    Refs:
  10. #25
    nvturbo's Avatar
    nvturbo is offline Senior VIP Member
    Nov 2012
    North Carolina
    158
    28 Post(s)
    I am using a "flared port" (Precision Port) in my setup. I was thinking about using slots but for my enclosure, a flared port worked due to size restriction.
    1997 Honda Del Sol Si
    * ///Alpine CDA-9851 CD player
    * Audio Control 2XS crossover
    * Soundstream Reference 500s
    * Precision Power PPI-2030M
    Front -- Morel Maximo 6 6.5" components
    Rear -- Pioneer TS-A1686R 6.5" speakers
    Sub -- American Bass XD1044 (pair)
  11. #26
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    Yeah i'm gonna use Precision Port too for my application, if that's what i end up deciding.
    Matt, My sub displacement is 0.14. is that for the single chamber and port on the side running the long way? did you use torres?
    I was hoping to get port and subs facing back, unless it wont make a difference?
    Omega, The 35" is total, because i need to fit it in my trunk....lol so there is room on the sides for sure but not enough to actually build with.
  12. #27
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    is this the design you were tellin me Matt? i don't know if i got all the numbers you used plugged in but it's close. is there any way to do a single box with two separate chambers?
  13. #28
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    yea i used torres. subs back port side. single chamber for seperate chamber just cut your width in half and use that measurement. give me a sec and ill figure it.
    Matt
    Refs:
  14. #29
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    i dont see how you can use an aero if you want seperate chambers. usnig a 4" aero you need like 20" of port length. yu could make it an "L" aero, but id just make it one enclosure and use a 6" aero.
    Matt
    EDIT, im guessing the sub displacment is .14 PER sub?
    Matt
    Refs:
  15. #30
    May 2012
    Cedar Rapids, Iowa
    17
    1 Post(s)
    yessir. 0.14 displ. per sub.
    is it still gonna be as loud as if i had slots firing back?
  1. Tube or Slot Port?
    By Psyence in forum Subwoofers
    Last Post: 07-18-2006, 10:26 PM
  2. Round or slotted
    By SlimShady16 in forum Enclosure Design & Construction Help
    Last Post: 04-22-2005, 02:33 PM
  3. Round or Slot Port???
    By BoomCrew in forum Enclosure Design & Construction Help
    Last Post: 02-19-2005, 12:48 PM
  4. Round ports w/ port noise or slotted vent?
    By pacho in forum Enclosure Design & Construction Help
    Last Post: 01-06-2005, 07:37 PM
  5. round or slot port
    By waNtsumBuMP in forum Enclosure Design & Construction Help
    Last Post: 08-30-2004, 07:06 PM
