Results 1 to 6 of 6
Reload Thread: 4th order vs vented wall
    Trevor28139's Avatar
    Trevor28139 is offline Member
    Dec 2012
    Rutherfordton NC
    61
    16 Post(s)
    i have a 2001 expedition with:
    2 DD 3515 CF
    1 DD M3A
    currently have a vented box subs firing up vent back.
    going to do a rebuild this weekend and trying to decide between:
    A fourth order with subs firing up into vented chamber with vented chamber firing forward, everything walled off behind the back seat.
    A vented enclosure subs firing forward vent firing forward everything walled off.
    my thought process is that if i wall off the space behind the back seat it reduces the amount of space to pressurize.
    my main focus is daily listening but would like to see a nice number on the meter as well.
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: 4th order vs vented wall
    I dont think that the dd's are suited for a 4th, but im not too sure..I think you should try a 6th order
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
    Dec 2012
    Rutherfordton NC
    61
    16 Post(s)
    i thought 6th orders were really hard on subs?
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Quote Originally Posted by Trevor28139 View Post
    Not if designed correctly, just like any other box. I agree, 6th order over 4th.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    Chriszle's Avatar
    Chriszle is offline CarAudio.com Elite
    Jan 2011
    SD
    1,718
    373 Post(s)
    I agree too. with DD's you gonna wanna go with a 6th or ported.
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    A 6th would be a fun build, but a 4th will work as well. If you are able to design/build it yourself try em both. The baffles for sealing it off should be the same for both options.
  1. Scion xB, 2 18's, 4th order wall!
    By 813thumper in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 12-30-2011, 03:48 PM
  2. 46panel's 4th order wall in the Explorer
    By 46panel in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 10-26-2011, 12:57 AM
  3. 93 cherokee 4th order wall build
    By orangecounty1 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 10-20-2010, 02:29 PM
  4. 4th order wall pros and cons
    By DDbump in forum General Discussion
    Last Post: 01-31-2010, 03:31 PM
  5. DD 4th order wall.
    By xtremebassjunky in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 12-13-2009, 08:01 PM
