+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Reload Thread: a couple ?'s for a new box!
  1. #31
    DbDesigns's Avatar
    DbDesigns is offline CarAudio.com Veteran
    Nov 2011
    mora minnesota
    4,331
    70 Post(s)
    Re: a couple ?'s for a new box!
    Quote Originally Posted by pro-rabbit View Post
    That is not true, most like subs/port down more then anything.
    I can pee farther than you.
  2. #32
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,099
    351 Post(s)
    Quote Originally Posted by RangerDanger View Post
    im talking about the fact that you cannot come at me about strength when you cannot properly draw the joints on an enclosure. I dont care about the design, it was never used. and btw, you wanted to do port on the top, yeah, that would have failed miserably in mwspl. just and fyi for your future skams. dustin is a scammer and a horrible person to deal with. he eats babies and loves to ride small black children around so he doesnt have to walk. he is actually kevin from skar.
    I don't remember what org it was designed for, but I do know the port at the top was the better option, there was even a thread where snoop and I discussed it.
    As for the joints, it was designed and would have worked 100% fine. I have said this many times now.
  3. #33
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,331
    70 Post(s)
    ok... lmao the goal of mwspl is to create pressure on one side of the vehicle. which a top port will not do.
  4. #34
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,099
    351 Post(s)
    I would have to look through emails to see what we discussed. I just remember what ever you told me port at the top was what I suggested for your application.
  5. #35
    splwj47's Avatar
    splwj47 is offline CarAudio.com Veteran
    Aug 2011
    Great White North
    24
    2,582
    29 Post(s)
    look at all the post dumping. and by a mod to. cool story fegs.
    2003 JEEP Grand Cherokee
    HU- pioneer 80prs
    Front Stage- Tantric HD comps.
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    Subs- Tantric HDD 12's
    box - 4.5^3 32hz
  6. #36
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,331
    70 Post(s)
    and I ASKED if you could do port center or port to the side. not demanded.
  7. #37
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,099
    351 Post(s)
    I told you the truth..then you told me what you wanted after I informed of what I thought.
    ---------- Post added at 10:52 PM ---------- Previous post was at 10:51 PM ----------
    Quote Originally Posted by splwj47 View Post
    This is true, ranger take to the dome if you want to keep up this convo...other wise leave this thread to the OP and his questions.
+ Reply to Thread
  1. time for a new box!!!!
    By AlpineUser in forum Enclosure Design & Construction Help
    Last Post: 10-03-2006, 07:56 PM
  2. i need some deminsions for a new box
    By robbie_tubbs in forum Enclosure Design & Construction Help
    Last Post: 05-05-2005, 04:12 PM
  3. time for a new box.....I ThiNK!?
    By Bavarian3 in forum Enclosure Design & Construction Help
    Last Post: 09-05-2003, 02:09 AM
  4. any suggestions on what to do for my new box??
    By bumpin_blazer in forum Subwoofers
    Last Post: 03-07-2002, 09:16 PM
