+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 37
Reload Thread: a couple ?'s for a new box!
  1. #16
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,375
    23 Post(s)
    Re: a couple ?'s for a new box!
    Those NSv2's are good enough to put in the truck free air. As long as they have 19 spiders.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  2. #17
    DbDesigns's Avatar
    DbDesigns is online now CarAudio.com Veteran
    Nov 2011
    mora minnesota
    4,306
    69 Post(s)
    Quote Originally Posted by gckless View Post
    25 actually...
  3. #18
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    Quote Originally Posted by RangerDanger View Post
    I am talking about the outer glue joints dustin. you should have interlocked them and you know that. I tweaked the design yes, i am not denying that. what I am saying is that you should not come at me about strength when you cannot even interlock glue joints on a wall.
    I didn't take the time to interlock the joints on the new design as I completely changed the whole thing to fit your "wants". For what you were doing, it would have been 100% fine is what I am saying. If you don't believe me build it. If it fails I will cover all expenses for that box and the new one.
  4. #19
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,306
    69 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    so I pay you 50 bucks... and you dont take your time. wow, great cs dustin, great cs.
  5. #20
    Why So Cereal?'s Avatar
    Why So Cereal? is offline Invisible Cereal
    Sep 2010
    Drowning in milk
    7,347
    74 Post(s)
    you missed the entire point of that post.
  6. #21
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    I didn't tell you to pay that, you did on your own.
    Then you had me design what was it 4 different versions(not altered version..totally different)....then you said I want this one...now.... Right now
    It was designed based around what you wanted...not what I thought would work best or perform best. Thus what was designed would have worked with in the designed requirements.
  7. #22
    bowhunter's Avatar
    bowhunter is offline Member
    Jun 2012
    Raleigh
    97
    hey i just had a couple questions but i like where this is going!
    1996 Dodge Ram
    2 obsidian 15 d4 v2's 7 cubes at 32 hz
    Hifonics Brutus brz2100.1
    Memphis pr4.50 on Alpine type r full range
    Eclipse CD5441
    Stinger 0 gauge and big 3, bigger battery, and stock alt
  8. #23
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,306
    69 Post(s)
    Then you had me design what was it 4 different versions..then you said I want this one...now.... Right now
    the only things that had to change was port placement and some minor dims because I had to re measure....
  9. #24
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    Quote Originally Posted by bowhunter View Post
    I would do some google searches for what worked best for some SPL guys, then look at what some of guys liked for daily...you will find that some things will cross over and others won't.
    Personally, I like subs forward and port up for daily.
  10. #25
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    Which had to change various characteristics of the design.
    Once you decided what you wanted it was designed around that. You keep dancing around the fact that it would have not failed what so ever. It would have been just fine with absolutely no issues what so ever. Well aside from a lack of output based on sub/port location anyway.
  11. #26
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,306
    69 Post(s)
    up and up center was loudest to the ear for me. sub up port side was okay, didnt like too much though. sub up port to drivers side was also pretty loud.
  12. #27
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    You're also talking about a small truck to a large truck. You have to remember that cabin size and other difference will affect how it performs. Just because a ranger liked one thing does not mean a S10 or full size will like the same.
    The other perk of subs forward is the ability to slim down the depth of the enclosure some as well...helps if you like to have your seat back a bit.
  13. #28
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,306
    69 Post(s)
    Once you decided what you wanted it was designed around that. You keep dancing around the fact that it would have not failed what so ever. It would have been just fine with absolutely no issues.
    im talking about the fact that you cannot come at me about strength when you cannot properly draw the joints on an enclosure. I dont care about the design, it was never used. and btw, you wanted to do port on the top, yeah, that would have failed miserably in mwspl. just and fyi for your future skams. dustin is a scammer and a horrible person to deal with. he eats babies and loves to ride small black children around so he doesnt have to walk. he is actually kevin from skar.
  14. #29
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,306
    69 Post(s)
    MOST trucks, not all, peak the lowest subs up port up center
  15. #30
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,060
    348 Post(s)
    That is not true, most like subs/port down more then anything.
+ Reply to Thread
  1. time for a new box!!!!
    By AlpineUser in forum Enclosure Design & Construction Help
    Last Post: 10-03-2006, 07:56 PM
  2. i need some deminsions for a new box
    By robbie_tubbs in forum Enclosure Design & Construction Help
    Last Post: 05-05-2005, 04:12 PM
  3. time for a new box.....I ThiNK!?
    By Bavarian3 in forum Enclosure Design & Construction Help
    Last Post: 09-05-2003, 02:09 AM
  4. any suggestions on what to do for my new box??
    By bumpin_blazer in forum Subwoofers
    Last Post: 03-07-2002, 09:16 PM
