Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Port Placement in a 4Runner
  1. #16
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,679
    29 Post(s)
    1130 Post(s)
    Re: Port Placement in a 4Runner
    Quote Originally Posted by UnderFire View Post
    I'm assuming you mean sub firing into the hatch, I'd really prefer not to have that set-up I don't trust ~2" of wood to keep the sub solid.
    Ya, I meant sub up port back port off to one side, sub off to other.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  2. #17
    double 07's Avatar
    double 07 is offline CarAudio.com Elite
    Nov 2011
    Etowah, TN
    1,960
    13
    3 Post(s)
    626 Post(s)
    Do subs up......port back......You can do port across bottom just build a center support that has a little size to it that will take up some of the port's width....It will serve 2 functions...Support the port wall and it takes up space inside the port so you can get the ratio correct.....You can see a small one in the middle of the box I done for Dtrom below......Just remember to take it's displacement from enclosure CF........
  3. #18
    CaddieJapan's Avatar
    CaddieJapan is offline Senior VIP Member
    Feb 2008
    Japan
    268
    60 Post(s)
    ^^^ Bam!!! Looks good to me....
  4. #19
    Nick32194's Avatar
    Nick32194 is offline Junior Member
    Nov 2012
    Oklahoma City, OK
    I have a 2004 4runner as well with 2 15's and the sub up position seems to work much better in clarity and in the reduction of rattles. As for the port position I would place it long-wise along the top with the subs, but that is just my oppinion because that hatch vibrates like crazy. Let me know how this build goes because I am planning on building a new box in the near future.
  1. Port placement in trunked car?
    By supermaxx123 in forum Enclosure Design & Construction Help
    Last Post: 05-16-2011, 10:38 PM
  2. Sub/port placement in an Explorer??
    By Fuknmovin in forum Enclosure Design & Construction Help
    Last Post: 01-25-2011, 12:43 AM
  3. sub and port placement in suv
    By 30hrtz in forum Enclosure Design & Construction Help
    Last Post: 12-11-2007, 10:20 PM
  4. port placement in a truck
    By MikeNeufeld in forum Enclosure Design & Construction Help
    Last Post: 08-05-2007, 03:45 PM
  5. Port placement in an RSX
    By Zxcvtypo in forum Enclosure Design & Construction Help
    Last Post: 06-22-2007, 10:33 PM
