Results 1 to 5 of 5
Reload Thread: 15 inch ID v.3 4th order 1.65 sealed 1.75 ported tuned to 50hz with 6 inch aeroport
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    15 inch ID v.3 4th order 1.65 sealed 1.75 ported tuned to 50hz with 6 inch aeroport-img-20130103-00050.jpg15 inch ID v.3 4th order 1.65 sealed 1.75 ported tuned to 50hz with 6 inch aeroport-img-20130103-00049-1.jpg
    The_Grimy_One's Avatar
    The_Grimy_One is offline CarAudio.com Veteran
    Apr 2011
    Phoenix, AZ
    4,236
    1 Post(s)
    565 Post(s)
    Re: 15 inch ID v.3 4th order 1.65 sealed 1.75 ported tuned to 50hz with 6 inch aeropo
    Very nice. Seems a lil small for a bandpass, but then again... I never built one.
    Deck: Pioneer 6900UB
    Highs: Pioneer TS-D1730C, Focal OEM Mids (Clarion NX-3410)
    Sub Stage: None (Sony ES XM-6001GXD)
    Bought From: ge_off_me, Boomsday, Chemmins, impactas, Sleazebagger, NoPh33rRaCiNg, fasfocus00, 50cents, flastrongman, pborcich, ace_800, GAMEOVERCCA, Ciaonzo
    Sold To: Jamesmington, Juicee, Bunkrd you, Donnie Darko, ge_off_me, destined2race, todd131, Imjtnotu, mclerico83, aimology, Audiobahn, kpetree, Souldrop
    Traded With: ge_off_me, Imtjnotu, 04lariat
    DFW40's Avatar
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    It is roughly what ID recommends I did another one for an Earthquake DBXi 10 and I cannot believe how good it sounds and it is midsized as well. The ID's are designed for small boxes. The large sealed is only 1.7 and it sounds great. We will see I might have just gotten lucky on the earthquake.
    DB-Audio's Avatar
    DB-Audio is offline Syko DJ music producer
    Mar 2009
    Newtown, CT
    2,654
    96 Post(s)
    gonna be trying a band pass as my next box probably sa 10 hope it turns out as well as yours
    2001 Honda Civic EX
    power acoustik 8" over sized touch screen
    doors Stock
    1- Atmos Audio 18
    1- Audiopipe 1000d mini @2 ohms
    Electrical stock for now
    http://www.youtube.com/watch?v=Cl_ardHXEkg"]My old System
    http://www.myspace.com/sykodjthereal"]If you Need Beats click this
    http://www.carstereoforum.net"]http://www.carstereoforum.net
    DFW40's Avatar
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    Try it it is like making a ported box pretty easy. I have done a couple and have always really liked the way they both sounded loud with a punch and good lows. I did make a third that ****** with and TC sounds OEM 10 it was very low low but had nasty high resonance that could not be crossed out. So I can see how if you do not use the right sub or wrong specs on box how easy it is to mess up. I like it because you can push it in the corner and really load it off the corner which adds silly db's easily plus you can throw gold bags on it soccer balls and do not have to worry about it. My 10 inch earthquake DBXI sounds like a good 12 ported. Shakes the hell out of the car loaded in the trunk corner.
  1. 4th order bandpass box seal to port ratio?
    By JeepGuy in forum Enclosure Design & Construction Help
    Last Post: 11-29-2011, 10:23 PM
  2. Single 15" Sub + Amp for a 4th Order in a trunk...
    By Dyme_a_Duzin in forum General Discussion
    Last Post: 04-25-2009, 02:20 AM
  3. 4th order build for the 06' XXX 15
    By mobeious in forum Enclosure Design & Construction Help
    Last Post: 02-08-2007, 07:20 AM
  4. Bad news on the 06' XXX 15 4th order build
    Last Post: 11-14-2006, 05:59 PM
