Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: the DEATHBOX II!! -_-
having a design made for 2 25W subs is not on my to-do list. i can get this design for free and if it actually worked as advertised then i would be fantastic.
Originally Posted by
IonRL205
What are you talking about? If who was blowing what?
I know boxes can't make subs handle more than the coil can handle.
My post was worded wrong.
I meant if you're having to use double the RMS to achieve the same output then it is a pretty crappy design.
Did you watch the vid on that link?
the guy in the video sure sells the thing good though. although even me being new to car audio and box building can't see how a box could change the peak power handling of a subwoofer and from info iv'e picked up from research here everysub woofer will sound different depending on the box it is in
Kangaroux
No lol
Headunit - Pioneer DEH-P8300UB
Subs - Two Kicker Solo x 12s Walled
Sub Amp - Shark Shkamp 2500d
Front Stage - Polk Audio db651 Coaxial
Front Amp - MB Quart ONX2.100 (coming soon)
zako
Most properly done 15 inch subwoofers are not suited for car audio use simply due to box size requirements.
By Trancer in forum Wiring, Electrical and Installation Help
Last Post: 07-10-2007, 01:09 AM
By DB4Me in forum Subwoofers
Last Post: 04-01-2002, 01:41 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
