+ Reply to Thread
Results 1 to 4 of 4
Reload Thread: 4 15s 4th Order Bandpass in a TRUNK?
    GeekSquad's Avatar
    GeekSquad is offline Senior VIP Member
    Jul 2011
    Columbia SC
    212
    15 Post(s)
    Okay, so I am working on a box for a Ford Crown Victoria. It can take up unlimited space but is confined to the trunk area. Subs are four Old School Kicker Solobaric S15-4s. These subs were designed around the theory that a subwoofer with twice the moving mass, motor force, etc will behave as an isobaric pair of woofers. This means that they are pretty inefficient, but play deeply in ridiculously small sealed boxes (Kicker calls for 1.5 cf per for these woofers). They are not reccomended for ported enclosures due to the heavy cone and relatively loose suspension.
    Since the current subs require sealed boxes, I would like to run them in a 4th order bandpass box. I estimate approximately 17.5 cf gross available for the total enclosure, so figure 14.5 after sub, brace, and port displacement. My impulse is to use one 6 cf sealed enclosure in the back firing into a larger ported side vented through the rear seat area.
    What do you guys think? Should I go smaller on the sealed side or keep it at 6? Port is 304 square inches or so.
    Amps are to be a matching pair of Old School Hifonics Gen vii Zeus and a single Gemini for now.
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    2,627
    131 Post(s)
    Re: 4 15s 4th Order Bandpass in a TRUNK?
    Sounds awesome. Get after it.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
    frogcase2002's Avatar
    frogcase2002 is offline Senior VIP Member
    Dec 2011
    hamilton, ohio
    476
    23 Post(s)
    You sure you have that much space in there. I just got done with a 4th order ported through rear deck and its pretty much my whole trunk and its one 15
    Jroo's Avatar
    Jroo is offline Senior VIP Member
    Feb 2007
    richmond virginia
    351
    Those subs sound incredible in 4th order. One of the best sub setups I ever heard was 4 round solobaric 12's in bandpass in a deville. It was clean and dropped low. I still keep my round 15" solobaric around. I wish kicker just improved on that design instead of going to the square stuff. Those mark the year that solos could sound good and everything after that went to pot IMO.
+ Reply to Thread
  1. (2) RE Audio 10" SX's in a 4th order bandpass ported through the rear deck of a Lexus
    By SHiZNiLTi in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-22-2011, 01:22 PM
  2. New dude in VA w/ S10 4th order bandpass
    By dustin_shull in forum New Member Introduction
    Last Post: 09-20-2009, 12:02 PM
  3. 4th Order Bandpass Preview/Suggestions Welcome (RD Alphamax 15)
    By GearGuy2001 in forum Enclosure Design & Construction Help
    Last Post: 06-25-2009, 08:13 PM
