Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Reload Thread: Help put two 15s in a Blazer, keep back seat.
  1. #16
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: Help put two 15s in a Blazer, keep back seat.
    Quote Originally Posted by pro-rabbit View Post
    3.5 is not large. As far as "getting away" with a smaller box, yes you can many times. However there is always something lacking. You can play low with a small enclosure as well, just not with the same type of intensity you can with a larger volume ith those drivers. The idea behind designing is to get the most from the subs in the given application. Not to "make it work".
    Sundown Ford Ranger ~ 2 - 15" Zv2 on SAZ-3500, 151+ db, Pure Pressure Concepts - YouTube
    those 15s are in less than 2.5 cu ft per sub. plays down to low 20's with ease.
  2. #17
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
  3. #18
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
  4. #19
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    You are a taking a very narrow and specific install and trying to apply that to all installs. We have talked about this before. That is simply not how this works. Let's not forget we are talking different subs and power and desired goals.
  5. #20
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    ive done it, and seen it plenty of times. those are simply the only videos that I could find. small with a good amount of port area works very well. plays flat, gets low. now I have never dealt with aq, so I may be wrong on that, but with every sub that I have used they loved a smaller box with a good amount of port area.
  6. #21
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    There is a balance to be had, but it depends highly on the application, goals, and product. There is simply no way to say this will work for all subs and applications.
    Also I did say you will still be able to play low in smaller enclosures and with various port area. However these is a give and take situation when designing.
  7. #22
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    because 6th orders.
  8. #23
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by RangerDanger View Post
    Then perhaps you should stop giving advice on subs you have NEVER built for
  9. #24
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by mlstrass View Post
    ok
  10. #25
    SquishY's Avatar
    SquishY is offline Member
    Dec 2007
    Hammond, Louisiana
    35
    1 Post(s)
    I've always had good results from the larger boxes we built with lots of port, and even the smaller 2 cube ones with 6" round ports. Post tax time be expecting a build log.
    Ran a main power wire yesterday, should be getting to my big three tomorrow. Box for one 15 until the second comes will be around 5.5 cubes with 17" of port per cube iirc. Might even get some videos of that up, should be in next week.
  1. Two 15" In trunk, trying to convince my friend to replace his 2 sealed with 1 ported
    By amartin_72 in forum Enclosure Design & Construction Help
    Last Post: 07-06-2006, 11:03 AM
  2. Box Help for XXX 15 in a SMALL ported box
    By hdave in forum Enclosure Design & Construction Help
    Last Post: 03-14-2005, 03:21 PM
  3. Help! Putting H/U in 2000 Focus, what's with the harness?
    By Jeff22 in forum General Discussion
    Last Post: 11-18-2004, 02:24 PM
  4. need help wiring two alt in one car
    By aphinney in forum Wiring, Electrical and Installation Help
    Last Post: 09-01-2004, 11:16 PM
  5. Need some help connecting my 15 in licker L7
    By gonzalez3063 in forum Wiring, Electrical and Installation Help
    Last Post: 07-27-2004, 11:59 PM
