no bass boost. I would have to go in my truck and see what everything is set on because I didn't set it up. im thinking about going obsidian or that other new brand that sundown came out with.
Changing subs isnt goin to help the hdc is a great woofer and sound great when setup right
i cant put the box anywhere else because of all the tools and parts in the van. i will check settings and let u know. thanks bro for your help much appreciated
That's much more helpful, and definitely shouldn't be an issue with the hdc3's. It seems NASTY08IMPALA is all over this.
No problem let us kno how it goes
i wish i could find someone around me that loves this as much as i do. everyone thinks that car audio is only for kids by me.
Local help is a great thing to have..try to drum up some help in your area from members on here
Could you get the specs of the enclosure? Like the H x W x D and what thickness of wood. Also the size of the port opening ( h x w) and the length of it.
We can tell you from that how the enclosure is setup. If you can get pics of your settings on the amp we can try and help walk you though that as well.
If you are getting a really good low end but not much from anything around 40hz then that is most likely a setting issue or enclosure issue though.
what about port area? what are u using for a port? If a slot is being used u should have around 15 sq. inch/ cu ft so if your slot is 15" it should be 2.5" wide.
i just signed up today so im trying to figure out how to use the site.
U will get there..lot of knowledgable guys on here..will help any way we can
i will get u all the info. thanks u guys are great
I'm up near Six Flags and have done a LOT of HDC set ups if you want to stop up sometime I'd be willing to look at the enclosure and HU/amp settings.
And please tell me that shockwave didn't do your box....
My Car- 2005 Ford Taurus
Headunit- Pioneer
Front Stage- building ..
Sub stage- 2 Dc level 4 xl upgraded 12"s
Sub amp- dc 3.5k (second coming soon)
Box- ~ SMS 4 cubes 32hrtz big ole port !!!
Electrical- Tenney 220 amp Lots of sky high 0 and some batts
Bought from- kangaroux / underfire / Tdford05 / Marleyskater420 / Mylows10 / double 07 / Vertex Audio / Pro-Rabbit / jock hater (Sold and traded too) /underfire / marleyskater420 / keefy248 / knotdrummer / vertex audio brandonkain82
Bookmarks
