+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Saw blade for clean mdf cut
  1. #16
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    Re: Saw blade for clean mdf cut
    Quote Originally Posted by nudels View Post
    the higher the tooth count, the finer the cut
    Yes, and the more power the saw needs. Too many teeth and the saw will bog down, bind, and burn the wood. So it depends on the saw.
    Quote Originally Posted by Kingstroker View Post
    Freud TCG blades
    My choice too.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
  2. #17
    DevilDriver's Avatar
    DevilDriver is offline Junior Member
    May 2012
    The D
    14
    I have been a residential carpenter for 15 years Diablo 40 T is prob your best bet
  3. #18
    nudels's Avatar
    nudels is offline KNOCK-KNOCK!, MOFAKOO!
    Jul 2011
    right here
    140
    1 Post(s)
    Quote Originally Posted by maylar View Post
    yeah, if you like to go balls-to-the-wall and force the blade to take on more material than it can handle.
    typically, the power needed to cut mdf *or any other material, for that matter* varies by how fast you feed the material combined with your blade depth, thus making the actual tool for the job a 'preference' as 'opposed to necessity' such as the question of blade, to suit the end result,.. but the question wasnt about a saw, was it?
    *edit, there was an old saying i took heed of when i first started doing carpentry, which was; "let the blade cut the material, not the carpenter"
    D.I.L.L.I.G.A.F.???
    refs; mlstrass, krazykilroy, 98ackCL23, 95k1500 , iamsonic, rustyarmadillo,alex95sl2, audiobahnfan, oldschooljunkie, oslouie, stills, rocksolid84, ellocogeorge, 350zkid, hurrication, jcorkin ,f3m4, juancolchado, coma_toast (sound_around) .. more than enough. ask, and ye shall receive.
    ca.comcacodiymasplc
  4. #19
    Kingstroker's Avatar
    Kingstroker is offline Mr Dique
    Oct 2012
    Guthrie, OK
    329
    1 Post(s)
    "typically, the power needed to cut mdf varies by how fast you feed the material combined with your blade depth, thus making the actual tool for the job a 'preference' to suit end result,.. but the question wasnt about a saw, was it?"
    You may get away with slowing down just a little but any more than just a little "typically" means your blade is getting dull or bade is too thick for saw hp(use a thin kerf)
    If you are cutting 3/4" stock of almost anything and you have to slow down your feed rate very much, you tend to build up heat. This will: burn your stock, dull your blade, create a varnish like coating of burnt material that builds up on your blade which will cause a uneven cut or even cause it to stop cutting. The more dense the material is the more likely all this will happen. Any info other than type of blade was added to be helpful.
  5. #20
    maylar's Avatar
    Jan 2002
    Connecticut
    61
    3,243
    8 Post(s)
    Not true. If you go too slow you'll burn the work and warp the blade. The blade must be matched to the saw and to the job at hand for optimum results.
    My point is only that you need to consider the saw when you choose a blade. The CMT Tools blade charts used to have a "minimum recommended HP" column for 10" blades. The more teeth and wider the kerf the more HP is required to get good results.
    dave
+ Reply to Thread
  1. Saw blade for cutting mdf
    By Beatkeeper1 in forum Enclosure Design & Construction Help
    Last Post: 10-19-2009, 06:17 PM
  2. What kind of saw blade for MDF?
    By GregU in forum Enclosure Design & Construction Help
    Last Post: 06-01-2009, 01:45 AM
  3. Saw blades - What to use for MDF?
    By Lurius in forum Enclosure Design & Construction Help
    Last Post: 08-02-2006, 01:01 AM
  4. What's that perfect saw blade for the jigsaw?
    By danteBirosel in forum Enclosure Design & Construction Help
    Last Post: 01-16-2006, 10:34 PM
  5. Replies: 3
    Last Post: 12-10-2002, 10:18 PM
