Results 1 to 6 of 6
Reload Thread: Best enclosure for SA 8v.1
    reible82nd's Avatar
    reible82nd is offline Senior VIP Member
    Jan 2011
    Lillington, NC
    420
    1 Post(s)
    78 Post(s)
    I just landed a pair of SA 8v.1s in a slot vented enclosure and the enclosure they came in clearly isn't made for them. What kind of enclosure will these things shine in? I've never owned a pair of Sundown subs, or anything else for that matter, so I'm at a loss.
    nkrell11's Avatar
    nkrell11 is offline CarAudio.com Elite
    Oct 2012
    Mt. Pleasant, MI
    809
    5 Post(s)
    209 Post(s)
    Re: Best enclosure for SA 8v.1
    Honestly they should do pretty well in a properly built ported enclosure or you could build a 4th order as well.
    Car:2004 Grand Prix
    H/U:Clarion CZ702
    Wires: 6 Runs Electron Beam 2/0
    Batteries: Juicebox Lithium 40ah
    Amp: Flatline 7k
    Substage:Custom Fi N3 15's
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    They don't need a ton of room really. They do like a bit of port area though.
    Any idea on the specs of the current enclosure they are in?
    reible82nd's Avatar
    Jan 2011
    Lillington, NC
    420
    1 Post(s)
    78 Post(s)
    I'll have to take some measurements of the current box. It's tuned pretty high though because it's more pronounced high higher frequencies but fades pretty quickly below 60hz or so. I discovered that these are v1.5s also. I noticed there were some free box plans on here, would a 1.6 ft3 tuned at 32hz do alright?
    reible82nd's Avatar
    Jan 2011
    Lillington, NC
    420
    1 Post(s)
    78 Post(s)
    Each sub is about .10 ft3 so the box plan I saw would end up being 1.4 ft3 net. Would the tuning change on the enclosure from 32hz after the subs are mounted?
    macsdad's Avatar
    macsdad is offline boom-boom
    Jun 2010
    Trussville, Al
    52
    2,807
    23 Post(s)
    817 Post(s)
    82nd airborne? I used to be a 13F in the 2nd128 Field Arty. They love small and low tuned boxes might have go aero on the port tho to keep it as small as you want yours. I know because mine had to go aero port.
  1. Best enclosure for Kappa Perfect DVQ?
    By ithrowgirls in forum Subwoofers
    Last Post: 02-15-2005, 04:34 PM
  2. Best enclosure for a 94'Honda Passport ?
    By Indybassman in forum General Discussion
    Last Post: 06-30-2004, 10:40 PM
  3. Best enclosure for a 2000"Dodge Neon Sedan?
    By Indybassman in forum Enclosure Design & Construction Help
    Last Post: 03-22-2004, 10:22 PM
  4. Best Enclosure for Focal 33K???
    By Epitaph to War in forum Subwoofers
    Last Post: 03-06-2003, 05:15 PM
  5. What is the best enclosure for 3 12's??
    By Trixter in forum Wiring, Electrical and Installation Help
    Last Post: 05-03-2002, 05:56 PM
