Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: Couple quick port questions.
  1. #16
    mklett33's Avatar
    mklett33 is offline Senior VIP Member
    Nov 2008
    MI
    417
    61 Post(s)
    Re: Couple quick port questions.
    Quote Originally Posted by mlstrass View Post
    Without a TL how do you know it's "the best it could be"?
    I did some testing on a 4th order build I did over the summer and added 4" PVC roundovers to various places inside the enclosure. I lost .3 - .6 everywhere I tried them. Would you hear that to the ear, obviously not, but just because on paper it looks good that doesn't mean it really is...
    Ugh, this keeps popping up everywhere, "I made an enclosure, tested it, then I added 45's and tested it, and it scored lower." Hmmm wonder why, perhaps because adding 45's removes net volume?
  2. #17
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    I've never seen a test with 2 boxes with exactly the same internal volume, one with 45's accounted for in the design and one without
    it's always adding them after like you said
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  3. #18
    PapaGeno21's Avatar
    PapaGeno21 is offline Captain Questions
    Oct 2007
    Rhode Island
    29
    570
    126 Post(s)
    Thanks for the input guys!
    Still debating on if I am going to bother, it is just for daily driving. Never will be measured, and honestly if it is such a close call I don't think it is going to be worth my time.
    No one is going to see it or even know the difference regardless.
    I am doubling my power as well, so regardless it is going to be louder!
    03 Suburban
    | Pioneer | Sundown | FU Audio | Rockville | XS Power | Sky High Wire | CDT | DC Power |
  4. #19
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Quote Originally Posted by mklett33 View Post
    While your statement is correct, how much volume do you think a few 45's take up? Not enough to drop .6 I can tell you that...
  5. #20
    PapaGeno21's Avatar
    Oct 2007
    Rhode Island
    29
    570
    126 Post(s)
    Doing the 45's will remove approx .18 ish of a cube for my plan. That only adjusts my tuning like .3 Hz... I am most likely going to do pic 2 as it is not that hard and I feel it will be better.
    03 Suburban
  6. #21
    PapaGeno21's Avatar
    Oct 2007
    Rhode Island
    29
    570
    126 Post(s)
    Well I built it. Won't have the sub for two weeks but that's ok.
    6.22 Net, 4.03 after port and sub displacement tuned at 34hz.
    First time using carpet on a box, so be gentle. I decided to carpet inside the port as well. First time using all thread style terminals. I did not want to attempt soldering 8 gauge wire to the radioshack style terminal you cut out the square for and mount on the box. I figured these will be more applicable due to the power going through them.
    Decided to go with pic 1. I figured out that putting the 45 in the corner (at the right distance) keeps the port at 5" wide, otherwise it got to 7" in the corner. I know I personally will not notice the difference with the other part having a 45 so I didn't bother.
    The circle aint bad for a jigsaw huh! LOL I hate cutting sub holes.
    03 Suburban
  7. #22
    PapaGeno21's Avatar
    Oct 2007
    Rhode Island
    29
    570
    126 Post(s)
    03 Suburban
  8. #23
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    looks good.my sale starts fri noon ,ab subs at a great price too
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  1. Quick Port Question!!
    By soulnomad in forum Enclosure Design & Construction Help
    Last Post: 07-22-2007, 12:12 AM
  2. Quick Port Question Please HElp
    By NoPh33rRaCiNg in forum Enclosure Design & Construction Help
    Last Post: 05-19-2007, 12:37 AM
  3. Couple of Port Questions
    By Hintzyboy in forum Enclosure Design & Construction Help
    Last Post: 03-19-2007, 09:42 PM
  4. Quick port question
    By Tiger Bass in forum Enclosure Design & Construction Help
    Last Post: 09-18-2006, 12:04 AM
  5. Quick Porting Question
    By ryanb9 in forum Enclosure Design & Construction Help
    Last Post: 01-30-2004, 03:45 PM
