Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Help with enclosure for 12" aq hdc4
  1. #16
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Re: Help with enclosure for 12" aq hdc4
    Quote Originally Posted by Julian View Post
    Enclosure volume does not effect port volume.... The displacement capabilities determine the port area of the subwoofer. Since AQ doesn't list the Xmax of the sub I'm assuming its around 25mm, with a tuning of 36 hz 50in^2 of port area would be about the minimum I would use.
    youre an idiot. say the enclosure is 3.5 cu ft. 3.5*16=56. 16sq inches of port per cu ft would be 56sq inches of port. and the xmax is not the only parameter used to determine the amount of port area that is needed...
  2. #17
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Using volume to find the port area is a flawed method. While it will "work" from time to time it is not the best option.
  3. #18
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    I do not use the volume to find the port area. I simply just state port area as xx sq inches per xx cu ft. its just a diff. way of saying it, instead of saying xxsq inches of port.
  4. #19
    myjaja's Avatar
    myjaja is offline Audioque
    Sep 2006
    San Antonio, Tx Posts: 143,632 _____<^>*_*<^>_____
    3,655
    492 Post(s)
    Quote Originally Posted by mlstrass View Post
    What calc are you using as that port length seems WAY off?
    If you end up doing 16^2 per net cube, then make the port around 20-21" long...
    Is it?? I was using 'the12volt.com' website to do some calculations. I think im better off paying someone for a design. Im not that good with slot ports compared to aero ports.
    Refs: sbcaprice305, mattmcss, systembumping, LeofromtheH, audiobahnuser18, stishdr, wcarson8911, jnoel, mr_kebo, 93 saturn sl2
    HU: Home stereo converted to dc
    Speakers: Stock
    Subs: 6 1/2 home sub
    Amp: off the stereo
    Wiring: extended power cord
    neon lights: Christmas lights duct taped to frame
  1. Help with enclosure for 4 9512's!!!
    By DropDownLowYota in forum Subwoofers
    Last Post: 09-28-2011, 10:44 PM
  2. Need help on enclosure for 12 12s
    By IbSlamn in forum Enclosure Design & Construction Help
    Last Post: 02-22-2011, 10:32 PM
  3. Replies: 0
    Last Post: 02-11-2010, 10:53 AM
  4. Need help with enclosure for 8 12's
    By kness_30 in forum Enclosure Design & Construction Help
    Last Post: 09-18-2009, 11:39 PM
  5. Need help with box for 2 12" RE SX's
    By awinter in forum Enclosure Design & Construction Help
    Last Post: 01-11-2005, 05:32 AM
