Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
door panel
Does anyone know anything about panel repair? I got a door panel in the mail and the guy sent it in a trashbag... the particle board wooden frame of it is bent. Ive watched videos on how to repair cracks in vinyl, but is there a way to straighten out the wood and then apply something that makes it stiff again?
If that makes sense
Re: door panel
Originally Posted by
GopsBynccounc
If that makes sense
Poast dump?
audioholic
I look for a girl with lowered standards, and possibly a vision problem. Depth perception and size awareness problems are a definite must. Also must like river-dancing and hideous, irreversible burn scars.
What can I say, Im an old fashioned kind of guy.
Re: door panel help
audioholic
Re: door panel help
I just cut a hole in my panel (originally 6x4) and set my ADS 6.5's in there (and built mounts, of course). I had to cut a little sheet metal out but that was easy. Not many choices wrt mounting because driver can get in the way of the window (when it's down). I have Sunfire '98 which looks similar to yours.
Re: door panel help
neonblack
But I want to have them fiberglassed into the panel
audioholic
Re: door panel help
also plan on removing metal to allow for adequate airflow into the door panel. the woofers need plenty of airspace - more than what the pods will provide. i agree your best bet is another wooden piece to outline the point where the mounting pod attaches to the door. a few dowel rods glued in place will allow you to position the mounting baffle as desired. that way you have a piece you can glass from a workbench and not on the panel - then cut out the panel, secure the pod to the panel (leave enough door panel material to allow you to screw them together. then seal, smooth, sand, and finish. are you going to paint or cover the entire panel?
with the additional weight of the new pods, you'll want to ensure the panel stays put and doesn't vibrate - additional screws or attachment points may be prudent.
have you been helped by me? i'd love to know. shoot me a PM.
My 2001 Accord build log:
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
Can I help you? valencebandacoustics@gmail.com
Want to learn about car audio electronics?
http://www.bcae1.com
Re: door panel help
keep_hope_alive
as far as covering, Im not sure yet. and on the door panel should I remove the arm rest and tuck the fabric behind there? Im just kind of hesitant to do that because they're riveted in there with plastic rivets. Do you think it would be find if I drilled them out, but then screwed then back in in the rivet holes, maybe with the addition of some locktite?
audioholic
Re: door panel help
you either have a pod that looks like a pod just mounted to a door, or you recover the whole door (or bottom half) for a seamless look.
Re: door panel help
keep_hope_alive
Im thinking about fiberglassing the bottom half, and making a seamless transition into the door
audioholic
Re: door panel help
knotdrummer88
you can probably just tuck the fabric into the seam with a metal putty knife. I'd be leary of cutting off the rivets unless you're 100% you can screw it back on strong since you pull on the door handle to close the door.
Re: door panel help
mlstrass
thats a good point, up until now I actually hadnt thought about what the door handle is actually there for!
audioholic
By gator1873 in forum General Discussion
Last Post: 07-05-2012, 05:45 PM
By shawn donkey in forum Enclosure Design & Construction Help
Last Post: 10-20-2009, 06:52 PM
By NoLimit in forum Wiring, Electrical and Installation Help
Last Post: 11-26-2006, 05:37 PM
By tskolrud in forum General Discussion
Last Post: 06-29-2005, 03:53 PM
By ActionJ-01-Z71 in forum Wiring, Electrical and Installation Help
Last Post: 03-03-2003, 12:18 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
