+ Reply to Thread
Results 1 to 9 of 9
Reload Thread: 30" x 2" Square port?
    Drummer65's Avatar
    Drummer65 is offline Senior VIP Member
    Feb 2010
    San Diego
    372
    4 Post(s)
    Hey guys
    Im helping a friend with a build for a DD 9515g
    Box is 4 cubes and the slot port would be 30" x 2" for a total of 60 square inches of port"
    My question is is the 2" of port sufficient in height or will air have trouble escaping the port? Do i need to do like 20x3" or 15" x4"?
    It would be much easier to do the 30"x2"
    Thanks
    Car: 2001 Honda Civic LX
    Headunit: Clarion EQS746
    Processor: Arc Audio PS8
    Front Stage: Peerless 830875 6-1/2" - SB Acoustics SB29RDC Tweeters
    Front Stage Amp: Vibe litebox Stereo 4 (Tweets) Punch 550.2 (Mids)
    Subwoofers: 2 x DD 9515g - 6 cubes 34hz
    Subwoofer amps:2 x SAZ-3500d's
    Electrical: DC Power 180HP, 2 Batcap 4000's, 1Batcap3000, 1 Deka 9a31 all in the trunk
    DbDesigns's Avatar
    DbDesigns is offline CarAudio.com Veteran
    Nov 2011
    mora minnesota
    4,319
    69 Post(s)
    Re: 30" x 2" Square port?
    nope. you will build too much compression with such a skinny port. it will mess with your tuning and it will create port noise.
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,456
    4 Post(s)
    too much skinny
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  4. Likes DbDesigns liked this post
  5. #4
    Drummer65's Avatar
    Feb 2010
    San Diego
    372
    4 Post(s)
    Yeah figured I would get port noise
    Okay so ill go with 15"x4" then. Does 60" of port area sound right for a DD 9515? About 2.5k watts going to it.
    I had about 95" for two on my past setup
  6. #5
    mlstrass's Avatar
    mlstrass is online now Shaggy DOA
    Jul 2006
    Illinois
    9,600
    13 Post(s)
    16^2 for DD's is the norm for daily.
    1:9 ratio for slot ports, so your 2x30 is not even close...
  7. #6
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Elite
    Apr 2011
    Dayton, OR, 97114
    1,750
    26 Post(s)
    I don't think That's how the calculation works, Try downloading Torres box calculator, it gives you the real port area as well as the square inches per cubic foot automatically.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Lanzar 6m
    Tweets: Crescendo CCX
    Fronts Amp: Alpine PDX4.100
    Sub Amp:Hifonics BRZ1.1700D
    Substage: 18" SSA ZCON
    Electrical: 160 Amp Alt, Duralast Gold, C&D270FR, 2/0 Throughout
  8. #7
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    The recommended DD box system uses 16sq in of port for every cube so you could go a little bigger to ~64sq in of port area.
    13 Dodge Dart Rallye 1.4T
    DD 2515 Supercharged
    RF T1500bdcp
    Audiotechnix wire and deadening
    http://mobileaudioforum.com/forum/forum.php
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
  9. #8
    Canaan's Avatar
    Canaan is offline Beatin' the block down
    Mar 2006
    Monroe, Louisiana
    1,432
    3 Post(s)
    Quote Originally Posted by Drummer65 View Post
    Hey guys
    Thanks
    No...no..no...please...NO.
    If you are thinking about a 30"x2" port for a DD9515G, just abandon your box design NOW!!!!!
    Please, let me help you. PLEASE!
    First off:
    What vehicle are you using?
    Second:
    What is your max measurements for the enclosure?
    I will have other questions, but you CAN NOT answer them without first answering these first 2 questions.
    Canaan White
    -'04 Avalanche, Eclipse 7200MkII, DD C4a, DD AT28 and AW6.5 (German comps) active,
    -2 DD3515E 6th order, 2 DD M2a @ 1.5ohm, 150+ @ 38hz
    Team South
    Desiard St. Pawn and Car Audio
    DD, Arc, Sundown, HAT and dB Drive Dealer
  10. #9
    Drummer65's Avatar
    Feb 2010
    San Diego
    372
    4 Post(s)
    Quote Originally Posted by Canaan View Post
    First off:
    Second:
    Yeah i'm not doing a 30x2 port
    I'm going with 4 cubes, 32hz with 60" of port area (15" x 4")
    Here is the box design. Sub facing up port is facing up on drivers side. Sub will be on top on the right side or directly in the middle of the box.
    Max dimensions 31" wide, 27" deep. 12" height towards the trunk lid and max 18" where the seats will be.
    Car is a 2004 Hyundai tiburon, so its a hatch.
    Attached Thumbnails Attached Thumbnails 30" x 2" Square port?-mchale-boxxxyy-7.jpg   30" x 2" Square port?-mchale-boxxxyy-6.jpg
+ Reply to Thread
  1. questions dealing with square ports
    By DarkFox in forum Enclosure Design & Construction Help
    Last Post: 04-16-2006, 11:47 AM
  2. slotted square port.... whats the diff
    By waNtsumBuMP in forum Enclosure Design & Construction Help
    Last Post: 08-29-2004, 06:04 PM
  3. Slot or Square Ports
    By havoc06 in forum Enclosure Design & Construction Help
    Last Post: 07-23-2003, 05:51 PM
  4. square ports instead of round ones.....
    By jefe1 in forum Enclosure Design & Construction Help
    Last Post: 03-15-2003, 01:50 PM
  5. Round port or square port?
    By Sspider in forum Wiring, Electrical and Installation Help
    Last Post: 03-22-2002, 08:07 PM
