Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: How to cut holes for subs
  1. #16
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Veteran
    Apr 2011
    Dayton, OR, 97114
    2,096
    1 Post(s)
    542 Post(s)
    Re: How to cut holes for subs
    To mark my holes, I take a nail and pound it into the direct center of the hole, use a tape measure, take the hook and hook it to the nail and follow the tape around the nail using the hook to keep it centered while keeping the pencil at whatever the radius is, takes a steady hand and some patience, but it works perfectly fine for me.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Pioneer ????
    Tweets: CDT DRT-25
    Fronts Amp: Memphis M-Class 4x50
    Sub Amp: Diamond D3 400.1
    Substage: 2x 12" Dayton HO's
    Electrical: 160 Amp Alt, Kinetik HC2400, Interstate DCM0100, 2/0 Throughout
  2. #17
    >>SQL<<'s Avatar
    >>SQL<< is offline CarAudio.com Elite
    May 2011
    USA
    1,457
    104 Post(s)
    Quote Originally Posted by UnderFire View Post
    Thanks for the tip.
    I think I am going to try to use a scrap piece of wood, drill a hole at the end and another 4.5" away and use that for my 9" hole I need.
    I have a package of jigsaw blades so I will take my time and hope for the best.
  3. #18
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Quote Originally Posted by xShoWTeKx View Post
    10$ circle homemade jig EASY - Car Stereo Classifieds
    i made 1 of these and it works very nicely
    Yep this is what I use except I made it outta some scrap wood. Drilled some holes that allow me to screw the jig right onto the base and it works great.
  4. #19
    shrowihr's Avatar
    shrowihr is offline Member
    Sep 2012
    dslfih,woiju
    119
    28 Post(s)
    Just use a compass.
  5. #20
    wErd's Avatar
    wErd is offline Maker of All Good Threads
    Nov 2003
    usa
    5,498
    347 Post(s)
    Quote Originally Posted by Kangaroux View Post
    Lulz
    refs: viveet, dvrmstrng,velobard,pickup1,rumblebee2
  6. #21
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Quote Originally Posted by bsipes30 View Post
    Just use a compass.
    Compasses tend to open up while you're drawing the circle, especially on large circles.
  7. #22
    >>SQL<<'s Avatar
    May 2011
    USA
    1,457
    104 Post(s)
    That is what I thought as well. I ended up using a paint stick, drilled a hole a bit from the end, measured 4.5" drilled another small hole.
    Screwed it into the baffle at the center of the hole I wanted and put a pencil in the other end. Worked really well and simple.
    Anyway what a royal PITA to cut it out with the 2 boards glued together. Took around an hour to cut one hole out.
    I need to go buy a better blade for the other hole.
  8. #23
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Quote Originally Posted by >>SQL<< View Post
    I buy a good cheap blade to keep from wasting funds. Odds are it won't be much of a blade when it is all said and done.
    Glad you're getting it done though.
  9. #24
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    OP go to HD/lowes and get the bosch jig set. It has plenty of different types of blades. The one in particular you want to use is the progressor bit. It cuts through anything I've thrown at it like butter.
  1. HELP cutting hole for sub!
    By bbobb123 in forum Subwoofers
    Last Post: 08-10-2010, 12:30 PM
  2. how to: cut strip and crimp hyperflex for
    By psychoacoustics in forum Wiring, Electrical and Installation Help
    Last Post: 04-30-2009, 01:29 PM
  3. how to cut sub holes
    By BigAl in forum Enclosure Design & Construction Help
    Last Post: 05-23-2008, 11:52 PM
  4. How to increse hole cut out from prefab?
    By zx12 in forum Enclosure Design & Construction Help
    Last Post: 08-23-2007, 12:30 PM
  5. how to wire 2 DVC subs to rockford 1000.1 amp
    By <muff_man_aj> in forum Amplifiers
    Last Post: 12-25-2001, 02:43 PM
