2 12" kove armagedon kmg-k pro box
got alot of room to play with. what would be best sealed or ported? how big and all. i built many boxes forgot the site i used and they all came out great but not alot of info on the subs. there dual voice coil subs to that i got for 40 dollars. so what should i do box wise? gonna run a 1000 or 1500 watt amp to it. im thinking 32hz ported. let me know your thoughts.
here are the specs
Revc = 3.54 ohms
Sd = 0.043 meters squared
Bl = 14.36
Vas = 51.92 liters
Cms = 197.7
Mms = 87.4 grams
Fs = 38.3
Qms = 5.43
Qes = .36
Qts = .34
Xmax = 14.0 mm
Xmech 40 mm
Coil diameter = 3" 4 layer single coil
Sensitivity = 94.0 ( 2.83v/1m )
PE = 800 W RM
Re: 2 12" kove armagedon kmg-k pro box
I sold my last set of these drivers about 5 months ago. Client came back for an enclosure we did 3.8ft3 net with generous port area and moderate tuning and they had a great response. Got low and loud sounded great.
