+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: ported box sealed from trunk
  1. #16
    double 07's Avatar
    double 07 is online now Supporting Vendor double 07 is a Supporting Member of the forum!
    double 07 is a Supporting Vendor of the forum!
    Nov 2011
    Etowah, TN
    1,913
    13
    286 Post(s)
    Re: ported box sealed from trunk
    Depends on the car I guess......This is my forward facing setup........It does a 147.5 @ 37 hz with my back seat in and sound only coming through center armrest....Mine is tuned to 36 and it plays music very well.....two AA Havoc 12s and a DC 3.5k wired @ 1/2 ohms nominal.............Oh and my car has ZERO RATTLES......
    It's the FINAL COUNTDOWN!!!!!!!
  2. #17
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,087
    18 Post(s)
    Quote Originally Posted by double 07 View Post
    Wow man that looks beautiful. Great work
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  3. #18
    double 07's Avatar
    Nov 2011
    Etowah, TN
    1,913
    13
    286 Post(s)
    Thanks...it does except for the sub on the right AA sent me a messed up re-cone a while back.....The coil assembly was glued in a little too high......That's why it has a dented dust cap........It didn't affect its output at all though........lol
  4. #19
    Falcons's Avatar
    Jan 2011
    5,087
    18 Post(s)
    Haha as long as you know your work is legit.
    aquire a 2k amp
  5. #20
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,120
    28
    128 Post(s)
    no great stuff foam for me.
    sealed off prevents phase interference from sound bouncing around in the trunk and arriving later. the extra output some trunks get is from constructive interference at a few frequencies (usually in the 40-60Hz range). but that means you also have cancellation at other frequencies. it is somewhat vehicle dependent since it relates to geometry. and it depends on the enclosure as well. sound off the rear of the sub will reflect off the rear box wall and come back out the cone. this plagues all speaker systems. controlling it is hard. it's why i gain output by opening my trunk. i eliminate the destructive reflections that come back through my woofer cones.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  6. #21
    May 2007
    Quad Cities, IL
    5,120
    28
    128 Post(s)
    the rear seat will actually help you by absorbing some harmonics - like an aperiodic membrane. i keep my ski-hole down most of the time - which allows plenty of airflow. but even with it up, i'm still happy.
  7. #22
    Falcons's Avatar
    Jan 2011
    5,087
    18 Post(s)
    I wish I had your car.
    aquire a 2k amp
  8. #23
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,147
    113 Post(s)
    Quote Originally Posted by falcons03079313 View Post
    i have a few questions.
    1.) how does forward firing sealed from the trunk help with sq? cleaner sound less rattle from other crap. smoother
    2.) what is usually the best tuning for a smooth roll off? or is this pure car dependant? if so im going to decide this for myself.
    3.) what do you guys use to seal the box from the trunk? great stuff in a black can
    4.) is there anyway i can seal off the box from the trunk and still be able to use my back seats? no
+ Reply to Thread
  1. subs facing forward and sealed from trunk good or bad?
    By ken72988 in forum Enclosure Design & Construction Help
    Last Post: 01-10-2008, 06:07 PM
  2. Can I fit two 15's ina ported box in my trunk?
    By Phreaker in forum Subwoofers
    Last Post: 05-07-2006, 11:53 AM
  3. Can i fit a ported box in my trunk?
    By ls1pimp in forum Enclosure Design & Construction Help
    Last Post: 08-01-2005, 02:17 AM
  4. How should i seal box off from trunk?
    By Meka in forum Enclosure Design & Construction Help
    Last Post: 05-26-2005, 03:25 PM
  5. ported box position in trunk
    By skatenc in forum Subwoofers
    Last Post: 03-21-2004, 03:38 PM
