+ Reply to Thread
Results 1 to 5 of 5
Reload Thread: Sealed box
    bigone5500's Avatar
    bigone5500 is offline Junior Member
    May 2008
    Louisiana
    Sealed box
    Is it better to use a partitioned box for two subs or will a single volume sealed box do?
    Seraphim38's Avatar
    Seraphim38 is offline Member
    Jan 2012
    WA
    52
    Re: Sealed box
    Since no one responded to this post I will. The common thought in car audio is that each driver should have its own sealed partition so that drivers don't end up pushing against each other, especially when enclosure space is limited.
    The truth is though, when you get into larger box designs that putting drivers into the same space isn't as much of an issue. In large format commercial subwoofer applications (which I happen to be an expert regarding), the most popular designs in the world happen to contain multiple drivers sharing the same vented enclosure space.
    My system: Pioneer/Morel/Arc Audio
    Profession: Sound engineer. One of the best.
    BrownVanMan's Avatar
    BrownVanMan is online now CarAudio.com Elite
    May 2009
    Minneapolis MN
    1,704
    6 Post(s)
    Re: Sealed box
    doesnt matter as long as they are wired correctly however seperating them does help if for some reason one f the woofers blows or something the other is still in the correct box.
    husker77's Avatar
    husker77 is offline CarAudio.com Elite
    Apr 2012
    Nebraska
    651
    5 Post(s)
    Re: Sealed box
    Well let us see if I can be completely wrong about something.
    Let's say each sub requires 1 cu/ft of space(just a number I threw out), if you partition them, basically two separate boxes you need to make it 2 cu/ft, but if the subs share the same air space they see 1/3 of the other subs air space. Not really explaining it all that well. But for the 2 in the common box you would only need 1 1/3 cu/ft, so if space was a factor it could help having them share the air space.
    oldschool4me's Avatar
    oldschool4me is offline Premium Member oldschool4me is a Supporting Member of the forum!
    Oct 2007
    ep, ohio
    4,797
    25 Post(s)
    Re: Sealed box
    would be ok if ran in mono operation. if your running stereo then no. i prefer separate chambers myself for reasons like mentioned about blowing one in turn likely blowing the other rather quickly and i like os a/b amps usually ran in stereo. depending on the install i would use them in complete separate boxes for install design or in some cases getting the boxes to fit in a trunk with limited access. a long time ago i tried this out. i used same subs in seperate boxes vs single box with no chamber separation and there was a noticeable difference. ...now in a ported design like mentioned it doesnt matter as much because the subs would not in a sense be fighting each other as they both would be forcing air through the port.
    REF's: Revrider1, Kevinn, darkhunter139, 2002XLT,
    lax916, bad @ss chevy, dropped_mazda, integra88, CRXBMPN, 88irocZ, the franchise, SlainNothing, pootie, khmer rouge, NewAgeKing, thegreatestpenn, oneill584, headless, scoob8000, Blados,ProjectPechkin, Krackerjack, CrownVicon24's, Louisiana_CRX, go_go_thrash, IonSQL, PBateman, ericoutdoorguy, Flomaster, B-roc, RetroAudioinc, ampjunkielikeme, bur1196, integra2468, illbmeubu, j3bus2k3, wgsj_fortvalley, l7runner, Fast1one, +many more
    Ref thread:
    http://caraudio.com/forum/buyer-seller-feedback/286493-oldschool4me-feedback-thread.html
    R.I.P Taylor Lampart (NewAgeKing) 5/13/1988 - 1/24/2010
+ Reply to Thread
  1. Replies: 2
    Last Post: 01-29-2002, 03:26 PM
  2. sealed box
    By dan_3 in forum Subwoofers
    Last Post: 01-28-2002, 11:02 PM
  3. Sealed Box trouble
    By mbakes in forum Wiring, Electrical and Installation Help
    Last Post: 01-16-2002, 12:05 AM
  4. sealed boxes
    By <the sh*t> in forum Wiring, Electrical and Installation Help
    Last Post: 12-27-2001, 07:41 PM
