+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: 12" Kicker Solo X enclosure help
  1. #16
    wickedwitt's Avatar
    wickedwitt is offline CarAudio.com Veteran
    May 2010
    Abilene, TX
    2,932
    34 Post(s)
    Re: 12" Kicker Solo X enclosure help
    Quote Originally Posted by n8skow View Post
    Ahh
    yah, mine made a lot of black coils when I had it... (they still work, and meter okay) - but the color change was a bit alarming
    All of my old grey cones the coil blackened badly, even on Kx1200.1s Like you said, still played fine, but looked like they had been smoked.
    Stupid Loud.
  2. #17
    dumpbeast86's Avatar
    dumpbeast86 is offline Member
    Nov 2012
    Jasper, Georgia, USA
    120
    i don't know if you are still needing box help, but i came across this thread, and here is the specs straight out of the manual for my solo x12. it sounds you would need the tuner setup. port tuning depends on port dimensions. follow what is here.
    Enclosures
    S12X
    Recommended Vented Enclosures
    -Tuner : 3 cu.ft. Port: 45 sq.in. x 18.75”
    Fb= 40 Hz, Pmax= 1400 W
    ( with 25 HZ subsonic filter)
    -SUV: 6 cu.ft. Port: 60 sq.in. x 6”
    Fb= 45 Hz, Pmax=2000 W
    -SPL: 6 cu.ft. Port: 250 sq.in. x 9”
    Fb= 68 Hz, Pmax= 2500
    (Above tuning freq. only)
    See below!
    The SPL enclosure is intended for SPL ONLY!
    It is designed to be used with test tones above 68 Hz!
    Playing music with frequencies below 68 Hz will result in
    very, very, very bad things happening!!
    For more advice on box building see your local Kicker dealer
    or the Choosing and Building Enclosures page in the Tech Tips &
    FAQs section of the Support area on the Kicker website,
    Livin' Loud | KICKER.
    2000 Land Rover Range Rover w/stock Harman/Kardon surround sound
    Kenwood Excelon KDC-X396
    2 Incriminator Audio Death Penalty 15s/8 cu.ft. @31 Hz
    US Amps AX3200DE
    Excessive Amperage 250amp alternator
    Big 3 & 2 runs of 1/0 Flexaprene welding cable
    1 shuriken(120ah) & 2 c&d's(77ah)
  3. #18
    Nov 2012
    120
    i know there is not much kicker love on this site, but the solo x is mean no doubt, and with the correct box and power/electrical, this thing will take severe punishment and do things just 1 sub should not do!
    US Amps AX3200DE
+ Reply to Thread
  1. rfp t2 12'' vs. kicker solo x 12''
    By FX_RYEN_04 in forum Subwoofers
    Last Post: 04-12-2007, 06:53 PM
  2. IDQ 12 or kicker solo 12
    By derek9087 in forum Subwoofers
    Last Post: 05-13-2006, 02:51 PM
  3. Memphis Mojo 12 vs. Kicker Solo X 12
    By ilaydit in forum Subwoofers
    Last Post: 12-31-2005, 12:17 AM
  4. Kicker solo problem please help!
    By acefabric in forum General Discussion
    Last Post: 08-16-2005, 02:48 PM
  5. orion h2 12" vs. kicker solo x 12"
    By 78nova in forum Subwoofers
    Last Post: 04-15-2004, 10:56 PM
Tags for this Thread
