Page 3 of 3 FirstFirst 1 2 3
Results 31 to 42 of 42
Reload Thread: Trunk wall?
  1. #31
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    Re: Trunk wall?
    Quote Originally Posted by Montana View Post
    So, a walled trunk is just your box pushed all the way up against the back seats , as far as they will anyway, and sealing it off from the rest of the trunk? pushing all air into the cabin giving it a hatchback effect?
    correct. some walls can be further back. but most need to be as far up as they can
    Quote Originally Posted by Chriszle View Post
    I've heard that if your box is louder rear firing, you will put up better numbers firing forward sealed. If your box is louder forward firing unsealed than rear firing unsealed, then you will lose by sealing firing forward.
    i have no clue where you got this.
  2. #32
    filtor1's Avatar
    filtor1 is offline CarAudio.com Elite
    Feb 2005
    Florida
    1,465
    21 Post(s)
    Re: Trunk wall?
    FWIW, I got my best numbers at my lowest tune and the best experience from a sub stage when I did subs and port forward and sealing the trunk off. I will never fire into a trunk again. The only real way to know what will meet your goals is to build and test. I gained 3+db even after dropping my tuning to 28Hz after forward firing and sealing the trunk off.
  3. #33
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    Re: Trunk wall?
    Quote Originally Posted by filtor1 View Post
    i love the trunk wall of mine. its MUCH smoother.
  4. #34
    filtor1's Avatar
    Feb 2005
    Florida
    1,465
    21 Post(s)
    Re: Trunk wall?
    Quote Originally Posted by CAT MAN View Post
    I agree 100%. It seemed to smooth out a nasty dip I had and was much easier to blend with my front stage. I wasn't chasing numbers though. I never did get to try another enclosure with a higher tune to see what it could do. I was just too happy to change it.
  5. #35
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    Re: Trunk wall?
    im at 32 and i had to counteract the low tuning with a smaller box and larger port so i could still at lease halfway have my peak in the 40s but it seemed i dont oh well
  6. #36
    filtor1's Avatar
    Feb 2005
    Florida
    1,465
    21 Post(s)
    Re: Trunk wall?
    If you are happy with the way it sounds and it meets your needs for output, no need to do anything. Even the best laid plans act totally different once you get everything installed and playing. Why were you shooting for 40's? Output?
  7. #37
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    Re: Trunk wall?
    40s for spl and brutality :p
  8. #38
    Chriszle's Avatar
    Chriszle is offline CarAudio.com Elite
    Jan 2011
    SD
    1,718
    373 Post(s)
    Re: Trunk wall?
    From Mr. Sears, one of the loudest trunks in the nation I believe.
  9. #39
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    Re: Trunk wall?
    Thats odd i just chatted with him. Never said anything like that.
  10. #40
    Chriszle's Avatar
    Jan 2011
    SD
    1,718
    373 Post(s)
    Re: Trunk wall?
    He posted in on Caco the other day. Of course, its a general rule, and not every single car will follow it.
  11. #41
    CAT MAN's Avatar
    Dec 2010
    Roanoke,VA
    8,131
    2373 Post(s)
    Re: Trunk wall?
    thats odd that he would say that. mine ws loud both ways.
  12. #42
    BAPEKC's Avatar
    BAPEKC is offline 2LT
    Feb 2012
    NYC
    209
    66 Post(s)
    Re: Trunk wall?
    Im going with a trunk wall with 2 15's. Hopefully its efficient!
  1. easiest way to seal off a trunk wall
    By CAT MAN in forum Advanced SQL/SPL Discussion
    Last Post: 06-06-2012, 10:07 PM
  2. Trunk Wall
    By 7ender in forum Enclosure Design & Construction Help
    Last Post: 06-13-2009, 09:38 AM
  3. Trunk wall
    By shakinghorizons in forum Enclosure Design & Construction Help
    Last Post: 10-03-2008, 12:08 AM
  4. Port opening and rear trunk wall distance.
    By tez4life in forum Enclosure Design & Construction Help
    Last Post: 04-24-2008, 08:58 PM
  5. Reduced bass w/ sealed trunk wall
    By more_spl in forum General Discussion
    Last Post: 03-25-2003, 06:48 PM
