i like it man. Really good job on ur first builld. Hell i may have you bulid my 4th order bandpass for me!!!!
TheBatteryMan
Dont get fooled by "the other guys".
And, it fits!
I just used those Kenwoods to see if it fits, I pulled it back out and put the two SA-12 D4s in there.
Bumping hard
/Done
(Don't care to make it look pretty[carpet], it's a personal box, making one for a friend now after he heard the improvement from my cruddy store bought box to a REAL box, I'll make that one look pretty.
Future box builder.
Now onto bigger and better things.
I'm glad you decided to build your own box, it is certainly a fun aspect of car audio in my opinion.
You mentioned using Liquid Nails, and while I have never used it myself, I find many recommend the method I use: Titebond, screws, and silicone for the edges/seams. Fiberglass also works for sealing, but if your cuts are precise silicone will seal everything up and take a lot less time to apply.
Anyways, keep up the good work, that is a good job for a first time builder![]()
Refs
.....Realm of Excursion.....
MajorPayne TEAM_HAVOC_SPL HexiBase
.....Car Audio Forum.....
Jybfan04 Jando86
I think you'll wish you put some bracing in there or double walled.
pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
ab vfl 150.4 ,2 pc 2150 ,
cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
NOR CAL DB DRAG JUDGE
http://www.dcsoundlab.com
1,000+ designs since March 2011...
I have my PM's turned off, please email at Ryan@RAM-Designs.com
You can do threaded rod with washers and bolts sandwiching each piece of wood to be braced. You can also do "window" bracing with MDF, or simply use a 2x4 with screws and glue. I prefer threaded rod as it takes up relatively little volume for the amount of rigidity it provides.
Refs
Jybfan04 Jando86
Bookmarks
