+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Reload Thread: Concrete SPL build
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,108
    28
    126 Post(s)
    Concrete SPL build
    I am building an SPL setup for a friend. I have the plan and physics will dictate all dimensions. I will share the build process, of course.
    End goal will be four Massive N2's and pair of Fi 18's in a mid 90's Astro Van. Will form a wall with two separate enclosures at the C-pillars to retain 4 seats.
    First is a single sub on a single amp.
    The enclosure will be 3" of concrete. I know how I am going to build the forms with 3/4" OSB.
    The first step will have the enclosure facing back, loading off a concrete "L".
    The suspension will be reinforced. the enclosure will be rigidly secured to the vehicle. Roof and doors will also end up being reinforced.
    Will be vented with a removable plug for SPL and run sealed for daily. Will use processing for the two modes.
    Any comments/experience from you with concrete builds is welcome.
    This will be fun.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  2. Likes husker77 liked this post
  3. #2
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,092
    25 Post(s)
    Re: Concrete SPL build
    In for badassness
    13 Dodge Dart Rallye 1.4T
    http://mobileaudioforum.com/forum/forum.php<
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
  4. #3
    Joseph7195's Avatar
    Joseph7195 is offline Can't Walk, I still F*ck
    May 2011
    Saltillo, Mississippi, United States
    33
    1,064
    9 Post(s)
    Tuned in for sure! You always give enough pics to explain everything properly and thoroughly, thus insuring I learn something. Plus I fap to a couple, sorry, nature of the game.
    Kenwood Xcelon Headunit
    Boston Accoustics Front & Rear
    Cadence United Series Vegas 4 Channel
    Cadence S2W12-D2
    Cadence United Series Dakota Mono Amp
    Duralast 1,000 amp battery, X-Static 2,000 Amp Battery
    Rockford Foagate 1/0 wire, and interconnects
    Cadence shielded RCA wire
    Dynamat sound deadening, Fatmat sound deadening
  5. #4
    May 2007
    Quad Cities, IL
    5,108
    28
    126 Post(s)
    He has a good Clarion HU, Jl C5 comps, and the comps will be amped. Goal will be daily SQ. some local shops use a TermLab in the pass dash corner for local comps, but I'll refer to other rule books to determine classes ahead of time.
  6. #5
    husker77's Avatar
    husker77 is offline CarAudio.com Elite
    Apr 2012
    Nebraska
    651
    5 Post(s)
    What is he doing for suspension, it has to weigh a ton, literally.
  7. #6
    May 2007
    Quad Cities, IL
    5,108
    28
    126 Post(s)
    Final weight is a concern, and the type of concrete mix will be chosen based on final design weight... But we live near Iowa, so if it can haul six Iowans around, it can haul some concrete...
  8. #7
    CAT MAN's Avatar
    CAT MAN is offline Banned
    Dec 2010
    Roanoke,VA
    8,147
    113 Post(s)
    i talked tto you on the phone about this. cant wait to see it _
  9. #8
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    33
    2,825
    11 Post(s)
    Why are you going with a 3" thickness, with a good portland cement you should be able to pour a VERY dense rigid enclosure and not have to go beyond 1.5" in thickness also portland has a very tight structure to it after it has set-up, it's usaually mixed with sand to change it's consistency but I would use as little of that as possible.
    electrical: Optima yellow top, big 3 in stinger 1/0g
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 2 Rockford T1 12's,
    sub amp: Rockford T1500.1BDCP
    Enclosure: center port(designed&built by JayDubb757)
  10. #9
    May 2007
    Quad Cities, IL
    5,108
    28
    126 Post(s)
    I agree thickness can be varied based on cement used. Which affects other variables. Thinner with higher density can weigh the same... But something I will consider. That's the input I am looking for.
  11. Likes The_Grimy_One liked this post
  12. #10
    chillin's Avatar
    chillin is offline CarAudio.com Elite
    Jan 2007
    Whistler, Canada
    1,802
    4 Post(s)
    Looking forward to seeing this
    Children are the future… today belongs to me!
  13. #11
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,472
    81 Post(s)
    But will it blend?
  14. #12
    May 2007
    Quad Cities, IL
    5,108
    28
    126 Post(s)
    Quote Originally Posted by Kangaroux View Post
    But will it blend?
    blend?
  15. #13
    audiobaun's Avatar
    audiobaun is offline Premium Member audiobaun is a Supporting Member of the forum!
    Jun 2011
    rockwall,Tx
    5,996
    36 Post(s)
    I have seen on construction sites that Foam has been used,and (chicken wire?) wrapped around that, and concrete sprayed on top of that, and felt pretty solid when finished.I have also thought about the concrete board that is generally used in commercial buildings for rest rooms/counter tops for tiling ect.just a couple of other ideas possibly for concrete structure.Yet, I am Subscribed
  16. #14
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,472
    81 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    blend?
    Nevermind, lol
  17. #15
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,829
    15
    89 Post(s)
    Quote Originally Posted by audiobaun View Post
    Heard good things about cement board. Laminate together a few layers of that with resin on top of a few layers of wood laminated together with resin.
  18. Likes subzero liked this post
+ Reply to Thread
  1. '61 Vette SQ, (NOT SPL) build plan.
    By BTLee in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 02-06-2010, 02:35 AM
  2. Ford Ranger SPL Build- DD 9510's
    By bunkerking09 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 08-13-2008, 09:40 AM
  3. Atomic AP/SPL Build
    By kickerlivinloud in forum Enclosure Design & Construction Help
    Last Post: 02-09-2007, 08:09 PM
  4. possible SPL build....
    By saywhat? in forum General Discussion
    Last Post: 12-22-2005, 07:21 PM
