+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Reload Thread: 03 explorer wall build help
    sleazebagger's Avatar
    sleazebagger is offline nobody!!!
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
    Icon11 03 explorer wall build help
    Building a wall for my 03 explorer designed by pro-rabbit and would like to get some advice on the construction since I'm new to this level of building.
    This will be set up behind the rear seats and take up the back hatch with enough room for a rack and batts.
    I have a local member thats helping me but he hasn't built one either.
    How would you start this process and what tips could you share?
    Thanks much
    What goes around is coming around
    chargdbassbuick's Avatar
    chargdbassbuick is offline CarAudio.com Elite
    May 2012
    Lone Star State
    755
    6 Post(s)
    Re: 03 explorer wall build help
    well bro i would start off by takeing off all the trim panels all in the rear, carpet etc. im sure your trying to get as much room as possible out of the build . hope i could help
    SOLD TO: bravomaster22,st0n3r,tankdylan001,Glaciersoul, BKNIGHTS, ArabonRadar
    BOUGHT FROM:bizzy07,psychoacoustics, davidtemple, JoeK #guesswho?
    TRADED WITH:
    Quote Originally Posted by jdawg View Post
    all cut, cant find anything good like 7 or 8 years ago, you know the economy is bad when you can find good drugs
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
    Quote Originally Posted by chargdbassbuick View Post
    I got enough room for the setup and everything is already deadened so I'd like to think that the final baffle in front will not only flush mount the subs and the removable port but also trim the sides for a tight fit.
    that back will be the same. My truck is nice so I don't want to start filling things in with great stuff and shizz.
    I believe the point is to seal the box as tight and thick as possible and contain all the sound I can to the forward section of the vehicle.
    right?
    I get worried that there will be a cancellation if I dont pack the sides with foam is this true?
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
    I guess people who build walls don't give a fuck about others who are trying to build one...
    selfish fucks
  5. Likes shpatb liked this post
  6. #5
    wes669's Avatar
    wes669 is offline Senior VIP Member
    May 2009
    Evansville, IN
    317
    1 Post(s)
    thats a great way to get people to help ya bro!
  7. #6
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,472
    81 Post(s)
    Sealing it off doesn't stop cancellation so much as it does just prevents the pressure from making it to the back of the vehicle...you could always use spray foam near the back of the wall and then just put a trim panel over it to protect. Get some 2" masking/painters tape and put it on anything you'll be using spray foam on, so that way if you ever want to tear it down in the future the foam won't be stuck to everything since it'll be on the tape.
  8. Thanks sleazebagger thanked for this post
  9. #7
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
    Quote Originally Posted by wes669 View Post
    I'm talking crap...
    I've had this up for a few days and usually people jump right in so I'm surprised
  10. #8
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
    Quote Originally Posted by Kangaroux View Post
    I own a painting business and thought about this approach. lol
    Since you brought it up I think I'll do it for more sealing. I was also thinking about using either bed liner in the back of the box or resin.
    What would you go with?
  11. #9
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,463
    4 Post(s)
    start with the base....you can use existing seat bolts or other areas to bolt it down. Build up from there going as wide and as tall as you can
    you don't need foam. Might sound kind of confusing, but all the way around the front edge of the box glue/screw strips of 3/4" mdf to the box set back 3/4". Then you make the trim panels out of 3/4" and that strip gives you something to screw the trim panels to and it sits flush with the baffle
    if that makes sense lol
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  12. Thanks sleazebagger thanked for this post
  13. #10
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
    Quote Originally Posted by bhsdriller View Post
    I think it does. lol
    so your saying that the space between the outside of the box and the vehical should have an extra layer of 3/4? on the front and back. So the trim panels are extra thick?
  14. #11
    bhsdriller's Avatar
    Jul 2007
    bakersfield,ca
    4,463
    4 Post(s)
    no not really....I'm talking about when it comes time to do the trim panels around the baffle, to make it sealed off. That strip gives you something to attach the finished trim panel to
    I'll draw a picture when I get off work
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
  15. Thanks sleazebagger thanked for this post
  16. #12
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
    you are awesome!!!
  17. #13
    bhsdriller's Avatar
    Jul 2007
    bakersfield,ca
    4,463
    4 Post(s)
    Uhh I can't do it right now...
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
  18. #14
    May 2010
    Madison, WI
    32
    3,236
    34 Post(s)
  19. #15
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,092
    25 Post(s)
    lots of beer and weed, best advice you can have for any build regardless of complexity
    13 Dodge Dart Rallye 1.4T
    http://mobileaudioforum.com/forum/forum.php<
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
+ Reply to Thread
  1. Swapping out 21" for new wall build ,help!
    By twistedchild420 in forum Subwoofers
    Last Post: 12-11-2009, 08:57 AM
  2. Wall Build *Help*
    By Winter_C in forum Enclosure Design & Construction Help
    Last Post: 09-16-2009, 05:04 PM
  3. need help with wall build 4 15's in SUV
    By MmatsproRodeo99 in forum Enclosure Design & Construction Help
    Last Post: 06-05-2008, 10:31 AM
  4. Help on a 18" MT wall build
    By skadude016 in forum Enclosure Design & Construction Help
    Last Post: 06-03-2007, 05:36 PM
  5. box/wall building help
    By 4xGmc in forum Enclosure Design & Construction Help
    Last Post: 06-26-2004, 11:28 AM
