+ Reply to Thread
Results 1 to 2 of 2
Reload Thread: 1991 s10 blazer box build sugestions RE MT18
    curtis1993's Avatar
    curtis1993 is offline Member
    Mar 2008
    riverton utah
    110
    Hey looking for anyone that has run a RE MT18 in a spl box. Looking to see the best internal cubes to run it in? It is going in my 2 door s10 blazer. thinking of running it with a single round 12 inch port partial internal and external on the port. 4K for power just burps. My cab peaks at 46hz so tunning will be near there. On a round port of that size what is a good ampunt of port per cube of the box? any help would be greatly appreciated. It is going in my 1991 s10 blazer I have been told sub up, port drivers side works best for these blazers anyone with experence your help is greatly appreciated.
    oxsign's Avatar
    oxsign is offline No Affiliation
    Jan 2006
    Sanford, FL
    5,346
    6 Post(s)
    Re: 1991 s10 blazer box build sugestions RE MT18
    My best in a blazer (and I've owned a few, lol) was sub up port back. However, I did have good luck with sub up port to pass side. I had it this way with a single 12" & 18".
    1971 VW Fastback
    System: being planned out as i'm writing this
    4 10"s (undecided)
    2K-2500 (undecided)
    4 mids/4 tweets (AQ)
    http://www.noaffiliation.net/index.php
+ Reply to Thread
  1. Blazer Box Build, 7.6cuft 30.5hz. (2 15'' PSI HCs, DSC Power, Aeros) *whoisasdf*
    By av8ter in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 01-25-2010, 09:52 AM
  2. blazer box build design?
    By btlking in forum Enclosure Design & Construction Help
    Last Post: 05-29-2007, 06:03 PM
  3. blazer box build design?
    Last Post: 05-28-2007, 10:14 PM
  4. RE SE 10 Box Building... Pics Inside
    By Slody4Futbol in forum Enclosure Design & Construction Help
    Last Post: 02-23-2005, 12:16 PM
  5. 1991 Chevy Blazer S10 4 door?
    By Plasmah in forum Head Units
    Last Post: 12-01-2004, 07:54 PM
