Results 1 to 5 of 5
Reload Thread: what material do you use for ports
    misterio's Avatar
    misterio is offline Senior VIP Member
    Feb 2004
    texas
    227
    I built a box thats ready for two 12's or 10's and it is sealed so far but im thinking that i want to go ported to make it louder, what material do u use for ports? pvc? if so what thickness... thinwall, sch 40, ?
    1995 Eagle Talon EsI
    H/U: Panasonic Mp3 player
    Amp: Hifonics Brutus 1500
    Capacitor: Audiobahn 5 farad
    Sub: 1 12" XXX at 1 ohm
    InhumanAcura's Avatar
    InhumanAcura is offline 1/3ofTEAM PwNAGE..*****es
    Feb 2004
    South Florida
    8,639
    43 Post(s)
    Re: what material do you use for ports
    9 times out of 10 a ported box will need to be larger in volume than a sealed box, so you might want to take that into consideration.
    PVC is fine for ports, keeping in mind the inner diameter is the useable port volume. Ideally the lower profile the PVC would be better because it doesnt take up as much displacment. You can look into Aeroports, which is basically a domesticated PVC for boxes that comes with flared ends rather than a straight cut.
    IMO a slot port is easier because you can make different ports for different tunes. You can t-nut the box and change them in and out on demand.
    Until the last year or so I always ran sealed, because I was ignorant on how much better the subs performed in a ported box. I dont think ill go sealed again.
    misterio's Avatar
    Feb 2004
    texas
    227
    so if i choose the thinnest PVC there shouldn't be a problem with it flexing?
    Feb 2004
    South Florida
    8,639
    43 Post(s)
    Im not really going to go out on a limb and say yes, get the thinnest, but yes within reason. If your on your way out and the thing is flexing and waving in the air, Id have to say get one a little thicker. I wouldnt forsee PVC flexing on you.
    Where you at in Texas?
    You can find those aeroprts on Ebay for pretty cheap, you just cut them to size and pop the ends on.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    If you can get the aero ports for a decent price, get them. I had a pair of 4" and liked them very much.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
  1. Poll: Best sound deadening material for the money
    By CWT in forum General Discussion
    Last Post: 03-11-2004, 09:42 AM
  2. Port Material
    By Berry47 in forum Enclosure Design & Construction Help
    Last Post: 01-18-2004, 10:42 AM
